Question about Motorola Radio Communications
Motorola pr400 static after transmission - Motorola Radio Communications
2 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: constant static
You have one of three issues: 1) You are close to another device transmitting on your frequency, 2) Your radio has a problem and needs service, or 3) You have a low, bad or defective battery.
What you can do:
--Try the radio at a different location to see if the problem is only at a certain location. This will tell you if it is simply interference by another device.
-- Check your antenna for damage, replace if necessary.
--Try the radio with another known good battery and see if the problem goes away.
--If you don't have another battery, try turning it on when in the charging cradle. (NOTE: Do not press the PTT while the radio is on the charger. This can damage your radio. The radio should always be turned off when charging, unless running a simple test such as this one.)
If these do not solve the problem, your radio needs serviced.
Posted on Apr 23, 2009
Hello how can i enable the camera on ms6837d
The same drivers work for PR400, so choose this next time you ask for drivers for your camera.
Here is the Windows 7 version to download.
Support For PR400
Oct 01, 2014 | MSI Computers & Internet
Why does my motorola cp200 speaker mic plug have intermittent connection?
The internal jack on the radio has a bad solder connection on it, very common problem in that model. Take it to a Motorola shop for repair.
Jun 07, 2014 | Motorola Speaker Mic Pmmn4013a Cp200 Gp300...
How do i remove the circuit board in the BPR40
PeteD.
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Mar 13, 2014 | Motorola Headset Mic Vl130 Pr400 Bpr40...
How do i figure out if my motorola pr400 is uhf or vhf
Model number:
AAH**K is VHF
AAH**R is UHF
AAH**S is UHF
Best regards.
Jan 30, 2013 | Radio Communications
The light won't come off
Is it mains or battery powered? what colour is the light?
Are there any other problems with the equipment?
Aug 28, 2012 | Motorola PR400 Rado
Mag One Radio - Static
If your BPR40 radios are all about the same age, it could be a sign of your batteries getting old and needing replaced. A bad or weak battery will cause the radio to exhibit static, and then eventually poor or no transmit. Check your battery date code first, it is a 3 digit number on the battery label, followed by a space and then usually a number 1. On the 3-digit code, the first number is the year, the next two the week of the year. 229 would be 2012 the 29th week. Replacement batteries should be available for around $35.
If you feel the battery is not the issue, you may have ONE radio which is causing the problem. Try using all your radios and testing by shutting off just one radio at a time. You may identify the culprit. Motorola offers a one year warranty on the BPR40, after the warranty is done, flat rate repair is typically available for $69.
Third possible cause is some type of interference in your area. If this is the case, your radios may need a PL code programmed into them, if you don't already have one. This will filter out unwanted noise or transmissions. Sidenote: If you've added any new computers or electronic office equipment recently, it may also interfere. Some foreign produced computers will lack the filters required in the USA to prevent interference with communications. Coiling excess cables can be helpful in stopping RF noise.
The second of static at the end of your transmission is called "white tail" and is common in all modern radios. There is a programming feature to eliminate most of the white tail noise, it is called reverse burst. Your radio dealer can reprogram your radios and add this to your radios, or future radios you buy. The trade-off with reverse burst is that you will loose the last of your spoken words if you do not hold your PTT an extra moment, as reverse burst actually transmits back or cuts off the end of a transmission to eliminate the noise. White tail is worse when mixing old model and new model radios together.
Best regards.
Jul 12, 2012 | Motorola Mag One BPR40 Two Way Radio
I have a MSI PR400 and my web cam stopped working
The MSI PR400 uses pre-installed Microsoft Windows drivers, I would try using this guide for updating a driver that isn't working properly.
If the webcam still does not work after this, I would suggest you to get in touch withMSI Support for further help.
Jun 03, 2011 | MSI Microstar PR400 Notebook
Where can I get a MSI PR400 Service manual?
google it there are several sites that have service manuals for all kinds of electronics might have to pay 10 bucks for 30 day membership but you can download service manuals for all your toys for future
Dec 11, 2009 | Computers & Internet
Constant static
What you can do:
Apr 23, 2009 | Radio Communications
Radio Communications Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
