Question about HP LaserJet M4345 Printer
Hp-4345 email not configured error
I keep putting the STMP gateway address, but after completing 3 scans the printer email button goes back to the email not configured default. Having to power off\on the printer seems the only other fix to get the printer to allow you to be able to scan again , then it repeats and shows not configured again after 3 or so scans...
5 Suggested Answers
SOURCE: HP OFFICEJET 7410 "NO SCAN OPTION"
Buy an Epson
Posted on Jul 26, 2007
SOURCE: HP JetDirect IP Address
how to assign the IP address to Hp color laserjet 2550Ln printer?
Posted on Sep 17, 2008
SOURCE: Deskjet F2210 wont scan
Click start
Click programs
Click HP
Click HP support center
Click Scan.
Ths scan button on the deskjeyt itself wont work, but the scand command done directly in the computer does.
Posted on Apr 06, 2009
SOURCE: HOW TO SCAN FROM SCAN TO BUTTON IN THE NETWORK FROM HP 2727MFP
You need to install the HP Scan software on each and every PC the MFP should scan to. In this software, you can create targets for the "Scan To" button. But: This is only useful when scanning with the ADF, because when scanning from the flatbed, you'd need for every page to hit the "Scan To"-button, press "Scan", wait for about a minute or two until the MFP has found the appropriate PC, and wait for the scan. So network scanning is unfortunately very limited with this machine.
Posted on May 05, 2009
How to fix Error 60.02 for hp 4345
Easy steps to fix Error Code Clr20r3 occur in HP Computer/Laptop/PC on Windows OS by dialing HP Customer Support Phone Number 1-844-355-5111 (toll-free) with the help of customer support services.
HP Customer Support Phone Number 1 844 355 5111 HP Help
Sep 08, 2015 | HP Office Equipment & Supplies
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
When I try to scan things to email it suddenly has started saying 'send error'. How do I fix this?
reconnect the printer to the internet!- some of yoiour setting have been lost or removed , run the installation program again.I.e. Completely Uninstall the printer from network then reinstall. making sure all settings are completed ( things like IP addresses, Gateway addresses,etc')
Oct 11, 2013 | Kyocera FS-C2126MFP Printer
Please tell me how to configure ip address in printer 4350
Press Check mark (SELECT button) to open the menus.
2. Use (UP button) or (DOWN button) to scroll to CONFIGURE DEVICE menu, and then press
(SELECT button).
3. Use (UP button) or (DOWN button) to scroll to I/O submenu, and then press
(SELECT button).
4. Use (UP button) or (DOWN button) to scroll to EMBEDDED JETDIRECT MENU
5. Use (UP button) or (DOWN button) to scroll to TCP/IP
Then: Select whether the TCP/IP protocol
stack is enabled or disabled. You can set several
TCP/IP parameters.
Select the TCP/IP CONFIGURE METHOD to
configure the EIO card. For the MANUAL option,
set the values for IP ADDRESS , SUBNET
MASK , LOCAL GATEWAY, and DEFAULT
GATEWAY
Nov 14, 2010 | HP LaserJet 4350 Printer
I'm configuring the workcentre for a small business that uses Gmail (which has similar authentication requirements to yahoo and hotmail). I am getting STMP errors on trying ports 25, 465 (SSL) and 587...
>> Current Workaround: I am using my ISP email which does not require SSL connection and goes through port 25. It seems to work fine like this. I have set the default reply email to the gmail address.
Yes, that is _exactly_ what you must do for "outgoing" E-mail from your printer going "out" to an arbitrary E-mail ID somewhere on the Internet.
Sep 24, 2010 | Xerox WorkCentre 3220 All-In-One Laser...
On the front panel of my L7680 all in one printer I usally get an option to scan to email, however I now only have 2 options 1. scan and repeat 2. scan to memory device. How do I get the full list back?
we need to perform a reset, it will take the pritner to the factory settings and this may help you,
the process of reset goes like.
unplug the power cable from the pritner >
then press and hold down the # key and 6 key >
while pressing and holding these keys plug in the power cable back into the printer and wait for 20 secs and then release the buttons..
after this the printer will re-initialize and this might take few minutes.. so wait untill it finishes and follow the onscreeen instruction as well.(if any)
Nov 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
How to wirelessly print to HP 2410v Photosmart printer
This is the official how-to for network setup from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00781863&lc=en&dlc=&cc=us&product=303759&lang=
Introduction Print the network configuration page and obtain the IP address, subnet mask, and default gateway address for the printer. Printing the network configuration page
  1. Press the Setup button.
  2. Press the arrow buttons to select Network and then press OK .
  3. Press the arrow buttons to select Print Network Configuration Page and then press OK . The Network Configuration Page prints.
Obtaining the IP address, subnet mask, and default gateway address The IP address, subnet mask, and default gateway address are printed on the Network Configuration Page
The manual link is here:
http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
Hope this helps:
WizardRepair
Jul 18, 2009 | HP Office Equipment & Supplies
Need to install network printer to DLink Router
It has been a few months, so you probably have resolved this -- but just in case someone else is looking to find out the IP address on the internal print server of an HP Laserjet 4000n printer so they can set it up on their network, here are the steps to find the IP address on the HP JetDirect internal print server:
1. Have the Ethernet cable plugged in to the router and the JetDirect 600n card and power it on.
2. Make sure display screen on printer says "Ready".
3. Press the Menu button on the printer until you see Information Menu.
4, Press the Item button on the right (+) side until you see Print Configuration page.
5. Press the Select button and a configuration page should print.
One page is the printer's configuration and the other page is the print server configuration page. If you have a good JetDirect card, and good connection to your router, the IP address of the printer, plus its subnet mask and default gateway should be shown on the EIO configuration page.
If the printer has been manually set with a static IP address, subnet mask and default gateway that will not work on your network, you will see the settings will indicate "Configured by" User Specified.
To clear those settings and allow DHCP setting, perform a cold reset on the JetDirect card, by powering off the printer, holding down the green "Go" button and powering it back on until you see "COLD RESET," let go of the green Go button, wait a couple of minutes, then run another configuration page to see the freshly assigned DHCP address of the print server.
Hope this helps someone.
Mar 14, 2009 | HP JetDirect 600N Print Server
Scaner computer comunication
These are the steps for Windows operating system.
First make sure you have installed the printer driver software installed sucessfully untill it shows fax setup wizard and complets the entire procedure.
All you need to check is first open solution Center> Go to Settings> And Email Settings> Checked which is the default email selected there if you have outlook select it (But your outlook has to be configure to send Emails fom youe PC) then click on apply and close.
Then in solution center click on scan picture or Scan Document the in the next window where you see (Where do you want to send the scanned images) Click on the drop down and select EMAIL after it has scanned and you click on accept it should open the outlook window on its own where you can put the recepients name and send.
But if in case your outlook is not configured then try the bellow link to configure outlook:
http://www.hostmysite.com/support/email/outlook/
You can also send email from the printer but to enter email address you will need the computer to manully enter email address after it opens outlook window
Good Luck let me know if any problem
Let me know if any problem.
Good Luck
Oct 01, 2008 | HP Officejet 6310 All-In-One InkJet...
HP LaserJet M4345 Printer Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
