Question about GE Washing Machines
Scrubbing noise when washing, no noise spinning
Just replaced lid switch and its overheating!
  • 2 more comments
  • stillbill55 Feb 08, 2012
    A repairman replaced a magnetic lid switch to fix not spinning/washing problem. That's when the grinding when washing/agitating started. No grinding when spinning. I suspected he dropped something or bent something while looking at belt. He came back and said it must be motor. Its under warranty but I don't want to put machine through unneeded repairs.
    see above
  • stillbill55 Feb 10, 2012
    The repairman changed motor. Did not fix problem of scrubbing. Put a crowbar under unit and "adjusted" something. Also greased pulley. I assume transmission pulley. I was at dentist so relied on wife for info.
    But still scrubbing, not as loud.
    Scholar:
  • 78 Answers
Dear Stillbill55,
Seems like thermostat, or timer. . . You said you have replaced a switch and now you have overheating too; have you checked tha the wiring is correct and not damaged?
I would consider pulling out the multimeter and take readings from the questionable components and see where you go. . . If you can supply me some of these reading details, I will be able to advise you more.
Yours sincerely
Ouszen
Posted on Feb 07, 2012
SOURCE: replacing lid switch on Kenmore 80 series washing machine
It's attached under the top panel but depending on the year of manufacture it could be on the right, below a hole where the strike comes down or on the left rear under the console.
Posted on Jan 07, 2008
  • 1028 Answers
SOURCE: Washing machine won't spin until open and reclosed the lid
sounds like transmission not resetting for spin properly replace transmission
Posted on Nov 21, 2008
jmgldsmth
  • 1889 Answers
SOURCE: replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
Posted on May 29, 2009
SOURCE: Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
Posted on Dec 11, 2009
me too...exact same washer and same problem...how do u fix it?
Posted on Jun 29, 2010
How do I fix a top loading washing machine that isn't spinning, agitating or draining?
if this is a top loader put a pencil into the lid switch opening if the machine spins and drains when the timer knob says it should the tab on the lid or the lid switch has failed...replace the switch or the tab that goes into the lid switch opening
Jan 26, 2016 | Amana Washing Machines
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Water will fill into my Crosley front loader CW5000 but will not start washing, rinse, or spin
Sounds like you have a motor issue, listen when you press the start button, if you hear any squealing noises or any of the noises the system usually makes doesn't occur, then you probably have a motor issue, you may need to have your motor replaced
Jan 05, 2010 | Crosley CW5000 Front Load Washer
Will not pump out the water
You have a bad lid switch. Open the control console. Remove the lid switch wire. Make a jumper wire from a insulated piece of wire. Insert it into the lid switch harness connected to the machine(not the cabinet). Turn the dial to spin. If it spins replace the lid switch.
If it makes motor noises and does not spin,replace the direct drive coupling on the motor.
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Washing machine does not spin
If the unit is making noise while set to spin but not spinning replace the motor coupling for the fix.
If the unit is silent when set to spin replace the lid switch for the fix.
Both are very common and not expensive plus easy to find online with the model number under the lid. Let me know if you have any other questions.
Phil
Apr 11, 2009 | Whirlpool Washing Machines
Doesnt spin out water
Your lid switch is broken.. to check open and close lid a few times and see if you can heard clicking noises.. if not replace lid switch.. good luck..
Jan 21, 2009 | Washing Machines
My BWD 129 washer dryer is not spinning or draining
I have a similar problem - washer wouldn't spin or drain. The problem with my Kenmore 90 series is that the lid switch needs to be replaced. It's a safety feature. During normal operation when the washer is spinning or draining - and you open the lid - the lid switch sensor knows that the lid is opened and then "stops" the machine. A new lid switch needs to be installed. I have picked up the part, but am still trying to figure out "how" to get inside of the washer. The only difference between what you describe, and my problem, is that there is no "unusual" noise coming from the machine. Hope this helps lead you in a good direction. Another good site is Bob Villa's site.
Jan 15, 2009 | Hotpoint Aquarius WD640 Front Load...
My model 80 top load kenmore washes but won't spin.
INSPECT LID SWITCH IT S WERE THE LID CLOSES SHOULD MAKE A CLICKING NOISE IF NOT IT NEEDS TO BE REPLACED
Jan 02, 2009 | Kenmore 24032\24036 Top Load Washer
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
