Initial DTV-372 The picture on the TV quit working. We were watching TV and the unit just shut down. When we turned it back on, there was no picutre. We have not been able to re-establish a picture since. When it quit working it was part of a home entertainment system. As part of that system the picture no longer works but it does produce the sound from each channel. Please help. . . .
SOURCE: Initial dtv-171 tv/dvd
My tv is the same model as yours was doing the same thing, I checked the voltage coming out of the adapter from the wall. should have been 12 volts, it was only 9. I replaced the power supply and has been working just fine.
Posted on Jul 14, 2007
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
Posted on Apr 30, 2008
  • 151 Answers
SOURCE: Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
Posted on Mar 29, 2009
  • 123 Answers
SOURCE: Receiver Sr5200 shut down in 5.1 mode
chances are you have the volume too loud and the speaker wires are crossed.
all speaker wires need to be with the positive on the right and negative on the left if you have them anywhichway than it will work on low volume and not a very good sound.
look closely at the wires and they should have a red or so color on one side or the wire jacket itself will have a round side and a flat side
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: Sound quit while watching TV
Try to do fine tuning with all tv chanels
Posted on Sep 28, 2009
How do I check the capacitors on an I initial tv model# DTV -372?
There are meters called ESR meters that you use. They are not really expensive. That is the best way. Other than that some can be spotted by looking for leaks or bulging.
Jan 24, 2017 | Initial Televison & Video
Initial DTV-372
The cord can be tested to see if voltage is reaching inside the set, if you get any power or other light on front the cord is ok.
Nov 04, 2012 | Initial DTV-171 17 in. TV/DVD Combo
I want to buy a AV cables for a initial 37 inch dtv-372 (db-4500
AV cable can be bought from most of the electronic spare part selleing shops at your town. It will look like this.
Nov 14, 2011 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
I have a VR-6025Z 60"
unplug TV and Bluray power cords from wall socket, replug HDMI cable in both units, replug power cords back in, turn them On and check.
Let me know how it worked. it seems Bluray player set its display resolution bit higher that TV doesn't support.
Please connect Bluray in TV by usual AV cable (yellow-red-white) and go to BD player setup menu and reduce HDMI Out resolution like 1080p to 1080i, then check it in TV HDMI input.
May 14, 2017 | Westinghouse LVM-42w2 Television
Sep 28, 2009 | Initial DTV-322 32 in. TV/DVD Combo
VS-45607 Rear Projection Television
Resoldered connector DY on the yokes and check caps C411, 2200uf/35v and C412, 10uf/50v on main pc board.
May 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Power problem
Remove back, reseat all connectors. It is a mechanical interrupt to the relay board causing the problem.
Nov 15, 2007 | Initial DTV-172 17 in. TV/DVD Combo
there is a box on the home of that says enter yor zip code to find a repair man near you just follow the instructions good luck.
Apr 07, 2007 | Initial DTV-171 17 in. TV/DVD Combo
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
