Question about Dryers
I need two 4.75MFD capacitors for my Heritage Lancaster series Ceiling Fans
I have two Heritage Lancaster series Ceiling fans and they both need the run capacitor as they are both bad and fans will not run. WHERE CAN I FIND THESE CAPACITORS. What I can read on the old ones is 4.75 MFD+/- 5%, 250V, 70Deg C , Series WS. Brand name appears to be Zhong Xing with a big characture " I" with feet in front of the name. These are rectangular shaped ceramic Capacitors with a tab used for mounting.
Thanks for any help you can give me on this.
Lee S.
  • 4 Answers
SOURCE: harbor breeze ceiling fan
Your voltage is probably too low, probably a bad wire or source. Let me know if it worked.
Or take a look at the link given here... http://www.ceiling-fan-wizard.com/harbor-breeze-ceiling-fans.html
Posted on Nov 21, 2008
  • 17 Answers
SOURCE: Aloha Breeze ceiling fan Model 5999
call 800-295-4448
They will send you one free of charge
Posted on Dec 23, 2008
JSEhandyman
  • 368 Answers
SOURCE: Fan does not run, light kit still works
Hi Larry,
Several possiblities come to mind.
1) Electric motors attract dust and lint; enough can either cause the motor to overheat or just physically clog. Regular vacuuming helps, but you may have to pull it apart to check (de-energize that wiring circuit first).
2. Look for any loose wire connections. If you have a multi-meter, use it to check for continuity between the various wires.
3. Look at the motor for signs of scorching or other physical damage. If the previous two steps don't fix it, you're likely looking for a new/rebuilt motor.
Fixing #1 or #2 are probably within the capabilities of the average homeowner; if #3 is the problem, you probably aren't going to rewind the motor - - you might want to check back here with an update (and feedback?).
SOURCE: Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
Posted on May 09, 2009
  • 57 Answers
SOURCE: Need a replacement capacitor
Voltage rating doesn't matter. 250v or 330v will work.
If this is really a 2 speed original, with the 2.5Amp motor... it will NOT have a capacitor as the motor is a shaded pole unit. The three speed electrically reversible fans, have a capacitor, which can either be in the switch housing/ oil reservoir, or the top of the motor housing, depending on year of manufacture.
Posted on Apr 01, 2010
I have one broken blade on the Heritage ceiling fan and would like to know if I can get a replacement blade?
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Accessories-Fan-Blades-Arms/N-5yc1vZbvne
Sep 29, 2014 | Heritage 52" Ceiling Fan
Fan motor not working on heritage ceiling fan taurus series after light switch failed
take the fan shrodwing off and check your wiring but before you do that check your fuse box it may just be a fuse
Jul 10, 2011 | Heritage (5EMW52AB3PF) 52'' Ceiling Fan
Heritage Ceiling Fan
You can try a univeral remote and that should work. You can buy one online at: http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
Jul 10, 2009 | Dryers
Power supply pull switch is broken
Just about any hardware store will have a replacement switch for your fan.They are a standard piece of equipment.You don't mention if it is the switch that controls the light,or the one that controls the fan.The light switch is a simple on off switch.The fan switch could be a simple on off switch or could have variable speeds.It may have an off position,and may not.You can tell if it is variable speed or not by looking at it.It will have more than two leads.You can decide for your self if you want an off position or not.For instance if you want to turn the fan off,and on from a wall switch you may not want an off position on the fans pull chain.
Jun 05, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Motor burned out. Where can I find replacement
if you can identify what type and model electric motor your fan is using, visit Grainger or Harbor Freight then ask them if they can query and match your fan's electric motor model with a replacement.
Mar 24, 2009 | Heritage Dryers
Heritage lancaster ceiling fan
Where can I find parts for this fan: Kids 30" ceiling fan multicolor - I need new fan blad arms
Jun 19, 2008 | Dryers
Dryers Logo
75 people viewed this question
Top Dryers Experts
