Question about Drills
Ive stripped down my makita 18v bhp451 combi drill and dont know where the 2 steel cylinders go from the gearbox end of the drill (i belive)
Had to open drill to remove a stuck chuck but 2 small steel cylinders/pins or rollers about 2mm diameter x8mm long fell out any ideas
  • Phil Steward Oct 21, 2012
    We're you able to find out where they go?
I answered this on a different post, Have taken apart the makita bhp 451 hammer drillHope this helps.
Posted on Feb 02, 2013
  • 425 Answers
Here is a parts diagram. If that still doesn't help you call Makita's customer service at 800-462-5482.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/BHP451
Posted on Mar 07, 2012
  • 313 Answers
SOURCE: chuck change
open the chuck fully and remove the scre inside by turning clockwise. insert allen short side in to the chuck & tighten
the chuck. hold the drill & hit the allen counter clockwise & do it again as needed.
Posted on May 29, 2008
SOURCE: Makita BHP451 Question
go with the hitachi, i've had 4 makita drills all with gearbox slipping. expensive to fix.
Posted on Feb 16, 2009
co7196
  • 3433 Answers
SOURCE: my chuck is broke , on my 18v makita cordless
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Posted on Sep 17, 2009
radar001
  • 1051 Answers
SOURCE: removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Posted on Feb 19, 2010
SOURCE: Broken Makita Drill 6408k chuck
If the chuck itself slips, you can tear down the outer layers (yes it is a bit brutal)
of the chuck until you reach the inner metal core. You can then try several things;
1 loosen it with a pipe wrench, provided you can get a grip on the axle of the chuck to counter the torque
2 Weld an allen key to the metal core of the chuck and use a firm rapid blow by a hammer to rotate it counterclockwise
3 Dismantle the final shaft with the chuck core, and set it in a vise with aluminium plates to protect it, while you turn the chuck with a wrench or pliers.
4.If there is no senter lock screw inside the bottom of the chuck it may be fitted with a thread locking compound. It will loosen easilier if heated with a heat gun or moderate gas heat.Only supply just enough heat to loosen it, or the hardening of the steel may be compromised.
Posted on Dec 02, 2010
Makita dril 18v stopped working
check switch it may have over heated and burned out
Oct 22, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Three makita batteries wont charge 18v li-on
I did get an educated electronics eng. tell me li ion batteries 4handtools,are manufactured to only be recharged a set number of times,to avoid tool damage.
Oct 13, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Fitting new gearbox to 8444d
that is a pain. when you take them out they have to go back in that specific way that specific place. if you don't get back just right the case won't fit back together. if you take it slow and only remove what you need to remove you may not have any trouble. you will have to remove all the case screws to get to the gearbox. everything is a tight fit.
Jul 04, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I have a li-ion Makita BL1830 18V 3.0Ah battery that can't be charged...when on the charger the bottom two lights flash red..it will charge my other battery, so it doesn't seem to be the charger
Sorry Mate your battery is dead...
The makita lithium batterys dont like getting worked hard quickly.
There is a chip in them that recognice each battery to each specific charger. Try another charger. This has not worked for me. Try anyway
Nov 01, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How do i re-assemble a makita 18v cordless drill
check out ereplacementparts.com and type in your model eg bhp451 they should have an exploded diagram.
Dec 21, 2008 | Makita 12 Volt Cordless Drill/Driver Kit
Maikita bhp 451 transmissions
the gearbox is good,what the problem is,is the nylon speed change ring that goes on the outside of the gearbox that takes the power of the gearbox,the end of the teeth,about 2mm or less strip making only noise when in 2nd or 3rd gear,,they sell it with the new gearbox and charge you,,,,,but you can buy it separatly,,,the part no.419558-2,,pick key 01820914
Nov 02, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Grinding noise
possible burnt out in the brush holder assy,checked the motor
Apr 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Dec 22, 2007 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
443 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
