Question about Sharp LC Televison & Video
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
This TV just gives me a steady blinking green Power Indicator. Unplugged for hrs. Reapply power and same result. I have electronics background and have fixed many lcd's with bad caps before. If I press the vol down, input and power and hold the tv resets and the power indicator turns red. I then hit the power button and the unit powers on after few seconds (the power indicator stays yellow tho) I removed back and inspected and all the caps look to be in excellent shape (I know this doesnt mean they are good) the Main Control board (with all the inputs and video chipset on it) has a yellow SM LED that is flashing steady when I reboot and power on. If I cut it on and off after doing the vol,input and power reset it will keep cutting on and off for a short time till I unplug the unit. Once I unplug it then I go back to the blinking green power indicator and nothing happens. When it does cut on after I do the reset, i leave it on the tv tuner but it cuts off after a few minutes (but I think that is becuase there is no video signal and it goes into power save mode?) Any help would be greatly apperciated..
  • Roger Rogerson Feb 07, 2012
    I just went back and rechecked my steps to make sure i explained it correctly. I was off on one part. After I do the Vol down,input,power reset and get the tv to turn on, it cuts off after about 45 seconds and goes back to the blinking green power indicator.
    It will only cut back on if I cut it off and on before it does the 45 second time then suts itself off..
  • Seth Alison
    Seth Alison Feb 23, 2012
    Hi, I have the same tv with the same problem. have you solved it yet?
    Thanks!
  • 27 Answers
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Posted on Feb 23, 2012
  • Seth Alison
    And you have a lamp out. Luckily I have a spare from another set. I will list them on e-bay
  • 4 Answers
I believe you have a problem in your regulater curcuit!
Posted on Feb 07, 2012
2 Suggested Answers
  • 517 Answers
SOURCE: Sharp LC-30HV4U with only steady red lights on
Good day!!!
If you have lit red lights on your TV every attempt to power ON..
That problem is usually cause of bad power supply board or main board..
If you need a step by step procedure on how to troubleshoot your TV you can go to this link and get service..
LCD HDTV ASSUMED TO FIX
Thank you for using fixya...
Posted on Nov 05, 2011
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Tv is coming on for brief period and shutting down also constant flashing of green led light on front of tv
I have a plasma that does the same thing. I don't know but have been told it is probably the power supply.
Jan 11, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
Dec 15, 2011 | Sharp LC-32SB21U 32 in. LCD TV
Flashing green power light with no picture
9-if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Nov 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
788 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
