Question about Bose Acoustimass 5 III System
Bose Acoustimass 5
Hi David,
Is there any chance to find somewhere the schematics and or service manual for Bose Acoustimass 5 Series III?
I am from Romania, my subwoofer unit is completely dead but the cd tuner is ok.
Thank oyu,
Werner
hwerner@rdslink.ro
  • 2 more comments
  • hwerner Oct 25, 2008
    i located and already received the schematics.tnx
  • George Teneza Dec 01, 2008
    I have this same problem, I would appreciate very much if someone here can share and sent to me the schematic diagram of powered speaker system acoustimass 5 model 2683. My e-mail gct4364@yahoo.com.
    Thank you
    George
    Palmerston North, New Zealand
  • Anonymous Jan 02, 2009
    I have the same problem...could you email me the link to the schematics?
    corbitt.white@gmail.com
  • mak2138 Apr 23, 2009
    Service Manual BOSE Acoustimass 5 series 3 manual .I need one.
  • 4 Answers
SOURCE: Bose Acoustimass 15 woofer, Replacement of RCA female connector
On the end opposite of the jacks (top of the sub opposite connectors) in the exact middle, there is a ratchet looking device (flashlight and magnifying glass reveal the little culprit) with a very small flat screw driver rotate the piece CCW until a small tab is protruding from the middle. Pu the palm of your hand on the plastic case and give it a small whack (in the direction of the jacks) it will move about a 1.2 inch. Lift straight up and the case will come off and reveal the connectors. Trust me, get a flashlight and magnifying glass and peer through the small crack between the cover and the box, you will see the little notch (encoder looking) rotating wheel
Posted on Dec 15, 2008
  • 3 Answers
SOURCE: BOSE ACOUSTIMASS SYSTEM 15 SUBWOOFER - NO POWER
All I did was unplug my surge protecter for a 1 minute and once I did that I had bass from the module again.  I am using a Belkin PURE AV power console.
Posted on Feb 11, 2009
dunnbiker
  • 8546 Answers
SOURCE: bose speaker connection
The Bose systems are SYSTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The Yamaha will probably blow them up if you manage to succeed with your plan.
Posted on Dec 28, 2009
  • 10 Answers
SOURCE: Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Posted on Mar 22, 2010
SOURCE: Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Posted on Sep 23, 2010
How find schematic diagram acoustimass 10 III
No kidding but "good luck". Bose doesn't like telling anyone anything about the workungs or specs of their products. You'll only hear them tell you "it's the end all, be all product". And you're blindly supposed to accept that.
May 24, 2016 | Bose Acoustimass 10 III System
Can i connect my bose acoustimass 800 with any other receiver?
hi,
Surly you can connect these speakers to any receiver. It has an active subwoofer and 5 passive cube speakers. It can handle power up to 150W.
ok
Apr 28, 2011 | Bose Acoustimass 6 III System
How do I connect my Acoustimass® 5 Series III Stereo Speaker System to my Onkyo SR506 av receiver?
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Oct 28, 2009 | Bose Acoustimass 5 III System
No power to my speakers. How do you open the amp? BOSE acoustimass 5 Thanks
A powered AM5 bass unit? Undo the 1/2 screws, tease out the toothed quadrant by 90deg then tap the plastic panel down/away from the toothed quad. not easy the clips are usually very tight.
Oct 10, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
Sep 11, 2007 | Bose Acoustimass 10 III System
Bose Acoustimass 5 III System Logo
759 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
