Question about HP Pavilion MS225 (AY587AA) PC Desktop
How do i get to the fans in the ms225
My computer is over heating
  • HP Master
  • 32,281 Answers
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Posted on Feb 08, 2012
How can I reset a hp pavilion ms225
Here's the page to the manual for that model
HP Pavilion All in One MS225 Desktop PC User guides
There's both setup and troubleshooting there. If you just want to reset the configuration to bypass a bad bios password, then all you need to do is remove the coin type battery that backups the settings. If the computer is over 3 years old, youmight want to thinkabout replacing that battery.
Jan 05, 2015 | Computers & Internet
Can hp provide the windows key number for a computer
No they cannot , you can however order new restore disks that will reinstall your operating system and all other software that came new with your computer.
Apr 30, 2014 | HP Pavilion All-in-One MS225
How to replace graphics card of a MS225 model HP?
Unfortunately, you cannot change the graphics card on this machine. Due to it's slim nature, the graphics card is integrated into the motherboard.
Apr 29, 2014 | HP Pavilion All-in-One MS225
Hp pavilion all in one ms225 can't get into bios how to bypass
Read through Curtis Sewell's advice to another person with another problem on the same computer.(It is the long answer near the bottom of the page)
http://www.fixya.com/support/t14662267-turn_hp_pavillon_all_in_one_ms225_sounds
Nov 22, 2013 | HP Pavilion All-in-One MS225
Cooling fan
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing and replacing the PC power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect ,boot up a computer hard drive
WARNING Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Test all leads that attach to your hard drive power and data cables IDE ,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
Make sure all leads that are attached to your dvd \ cd floppy drives have secure connections and are not faulty or just replace them they could be faulty.
Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error.
Even something as small as a faulty electrical or fan lead can cause you problems
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
May 26, 2013 | HP Pavilion MS225 (AY587AA) PC Desktop
Whining noise , temps look good?
Hi app,
I would check your fans to make sure they are clean and that no wires are rubbing on them. Hope this helps.
Feb 19, 2013 | HP Pavilion MS225 (AY587AA) PC Desktop
How do I access motherboard in HP Paviliion MS225?
Not sure, the directions show a desktop. Besides it only has 1 PCI exp mini slot already in use.
Tour the specs
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07139&cc=us&dlc=en&lc=en&product=4109937#N240oduct=4109937
Nov 30, 2012 | HP Pavilion MS225 (AY587AA) PC Desktop
How to replace an screen on an hp ms225
Hello
It is a very skilled job indeed. You have to contact the authorised service center for Hp in this case. Sophisticated toos, and good knoledge about computer hardware is a must to do this job.
Mar 03, 2012 | Computers & Internet
Fans are not working in desktop
Feb 07, 2012 | HEWLETT-PACKARD Hewlett Packard Pavilion...
When I turn on the PC the screen is blank. How do I replace the video card?
Are you sure the computer even boots up?
Could be a faulty power-supply...
You probably have to resolder the graphics BGA-cip.
http://h10032.www1.hp.com/ctg/Manual/c02043554.pdf
Good Luck :)
Aug 18, 2010 | HP Pavilion MS225 (AY587AA) PC Desktop
HP Pavilion MS225 (AY587AA) PC Desktop Logo
315 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
