Question about Electrical Supplies
COLEMAN CLEAN MACHINE MOD PW0811500. PUMP OIL CHECK LOCATION
Generator sat unused 2 years. whatshould be done before using for long periods
Change the oil and you will probably have to rebuild the carb. If it has a starting battery, that will need to be replaced as well.
Aug 10, 2014 | Coleman Powermate Powermate 5000W...
What kind of oil goes in my coleman pump model 17 msp
Coleman pump model 17 msp is a submersible electric pump and doesn't use oil.
Sep 30, 2012 | Electrical Supplies
Chain is not getting oil. 3 hours on new 455 Rancher chain saw. I have clean everything on the bar and the oil outlet. Do I need to have a new oil pump installed?
I saw many issues with the oiler on this model, the oil pump itself never goes wrong, there was a later filter as the original was too fine and would not allow sticky oil through, there was also issues with the oil pipe kinking and not allowing oil through, there was also a mod to increase the oil flow,it meant removing the oil pump shaft and increasing the throw by grinding the back of the pump shaft, if you have cleaned the externall oil ways and the problem persists,then it does lie deeper, you could try to thin the oil out and try again, if no better this will be a shop job. If you feel you could do it yourself, let me know and i will try to go through the mod with you.
Mar 06, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Maytag Mod. MDB4050AWW
Check inlet water flow. Clean the strainer located near the hose end on the machine.
Check the water pump and it's electrical connections.
May 27, 2010 | Dishwashers
Kenmore sewing machine mod 1703 motor runs but
By 'The wheel the belt is on' you mean the motor pully? If that is so obviously some oil has some how made way on the pully and the belt. Try to remove the belt and clean both wheels and the belt free of oil. This shd slove the problem.
If it doest then please send a photo of the arrangement showing pully and belt. U didnt mention if the machine is old or new. Did u oil it recently before trouble developed?
Oct 17, 2009 | Kenmore Sewing Machines
Rotary air compressor oil leak all over
First of all clean the machine inside the casing,the motor, pump I mean every where whth no trace of oil be seen in the machine.check the oil level sight glass,if level is ok. start the machine and if you see oil leaking at a hose ,stop the machine repair the leak and clean again, and restart the amchine and check and repair till all leaks are settled.
Sep 07, 2009 | Air Tools & Compressors
Coleman Powermate pressure washer PW0872400.01
The systems are simple but if they aunt stored correctly(allowed to freeze) or the air isn't purged out of it. It can result in damage to the machine.If water is dripping out of the pump it is damaged. if not then it could be air (purge system), or a damaged or stuck check valve.
Apr 26, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman 1600 pressure washer
Remove spray tip and clean with a paper clip, Check pump oil resevior and add 10w 30 pump oil if needed, also look for turn knob ,usually black with -+[plus /minus symbols ] and turn towards plus for extra pressure. May need new pistol/wand assembly and make sure hose is clear by seeing if water will run through hose freely and generously.
Thanks Kf1013 and please vote me a Fix Ya!!!
JJ505
Apr 13, 2009 | Coleman Pressure Washer PW0881800
Electrical Supplies Logo
91 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
