Question about Pioneer Audio Players & Recorders
VU meter does not issue the light of True Pioneer Amplifier SA606 and Tape deck CT 606
SOURCE: CT-W602R Dual Cassette Deck- door won't open
had same problem, just changed the belts and works like new.
Posted on Nov 18, 2008
Grubhead
  • 5487 Answers
SOURCE: Sony tape decks model tc-355
Follow the left channel lead to where it joins with the PCB. Use a pointed tool and prod connections if you get a buzz then that stage in the amp is working. I suspect you will find it leads to a IC that might cause the fault. If you find it buzzers on the right but not left, then it's gone. PS don't short pins. If you can get hold of a signal injector it will make things easy.
Be careful and good luck.
Posted on Jan 22, 2009
Grubhead
  • 5487 Answers
SOURCE: Technics Tape Deck RS-M227X. VU needles jump to the maximum right
More than likely the pre-amp IC has failed! Trace the wires from the VU meters back they should locate the source of the problem. Remember it will be something common to both channels!
Posted on Nov 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a pioneer CT-F900
The take-up reel is dragging or the belt is stretched or broken. No surprise on a deck this old. Try Fast Forward. Try Rewind. Same result?
If it still doesn't work, and it happens with only one cassette, rap the cassette's flat side against a solid flat surface to loosen it. Try again.
If you're really an old-school deck user you probably know how to cheat the transport with no tape resent to make the capstans engage for cleaning. Try that. The two reels should spin opposite as if maintaining tension. If the right one is stationary or lethargic (try to feel how strong it pulls compared to the left one), there's a loose or broken belt.
Next step. Get out the can opener, go inside and see what's wrong. Good luck.
Posted on Dec 26, 2010
SOURCE: I have a Pioneer CT-W302R
belts and instruction for measuring can be found at studiosoundelectronics.com
Posted on Mar 11, 2011
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
I have a teac 2300s tape deck. My problem is when i press the rec / pause or rec play the 2 meters slam to the right. They don't move while recording,but the deck will record and playback. Putting the...
The leads to the VU meters have shorted out. The fact that it only happens when you push "Record" sounds like part of the mechanism is actually causing the short.
Jul 15, 2017 | Pioneer Rt-1011l Reel To Reel Tape Deck...
Pioner cassette deck ct.f700 one vu meter does not work
Most likely a dirt switch contact in the unit, Clean with Deoxit and check again. Otherwise it could be a bad solder joint or a problem in the meter drive circuit. You might need a Technician to check it out.
Nov 13, 2012 | Audio Players & Recorders
My pioneer ct-f7171 cassette deck needs a little speed adjustment, where is the pot located?
Usually on the back of the servo motor. You need a speed alignment tape and frequency counter or wow and flutter meter to do this adjustment correctly. Often times the speeds go up as the motor start to fail.
Aug 12, 2011 | Pioneer Audio Players & Recorders
Is there a manual available for Pioneer CT-5310 please? +CT-W650R
HELLO
For FREE manual downloads try a site on the web called diplodocs.com
You'll have to fill in a small questionaire on the item (takes seconds) before you can download!
Hope this helps you!
Apr 08, 2010 | Pioneer CT-S250 Dual Cassette Deck
PIONEER CT 670 user manual ,in need,thanx a lott
You can try to download the manual from the following site.
http://www.fulldownloadshare.com/finder/PIONEER+CT+670+tape+deck+manual.html
I am not sure how big it is, but you can at least look at it if you don't want to print it out.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Feb 08, 2010 | Pioneer Audio Players & Recorders
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
49 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
