1)Call your Voicemail access number, or press its corresponding shortcut key (usually the number "1").
2)Press the key corresponding to "set your voicemail greeting" or "Set up your voicemail."
3)Decide whether you want to use an automated greeting, which usually gives out your number and advises callers that you're not available.
4)Follow the prompts to record and save your greeting.
Call your voice mail by calling your cell number on your phone if its the first time your service provider will tell that you need to set up your voicemail but if not when you call your first mail its telling you for mail box options press 3 or voicemail options press 4
hi,its a flex problem and i will advice you take it to a mobile phone technician to help you fix it up by changing the one that is there.its a minor fault.thanks.
I think you'll need to go into menu - settings and tools - sound settings - alert tones, then it should give you choices on what you want to change. Text, Picture, Voicemail, etc...
Call customer service something odd is happening you don't need to re-set up voicemail moving your SIM from one phone to another. If the phone is one not from your carrier it might not be programmed for your carrier's number when you press and hold 1 to dial voicemail
Go to Main menu, then "Messaging". Within Messaging go down to "Message Settings". #3 is voicemail. click voicemail and you will be able to edit the number.
