Question about Epson Stylus Photo 750 InkJet Printer
Epson 750 waste ink pad full
Ink head not cleaning and waste pad is full of ink.
    Scholar:
  • 78 Answers
Dear Hugh Slaven,
You will need to go to the support section for Epson, and read their troubleshooter, but I reckon you will have to manually remove the cartridges and then clean/ change them, then clean the printer, try then re-calibrating after that and see how you go.
I hope this is the fixya for you and look forward to hearing how you get on.
yours sincerely
Ouszen
Posted on Feb 07, 2012
  • 16 Answers
SOURCE: R300 ink Pads
http://www.stevesforums.com/forums/view_topic.php?id=51595&forum_id=40&highlight=R300+container
Posted on Nov 12, 2007
SOURCE: Epson R230 ink & Paper Lamp Blinking
I have an EPSON STYLUS PHOTO R230 series.. INK and WASTE led were both blinking..i restted it already... but the last one.. i can't reset it anymore.. the printer is indicating and saying "Remove foreign Object in the printer" .. what posible damage it has.?. thank you
Posted on Oct 08, 2008
Nic61
  • 1073 Answers
SOURCE: Epson rx620-waste ink pad replacement Instructions
No Problems M8!
Here is the manual for your printer
http://files.support.epson.com/pdf/rx620_/rx620_qr.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
Posted on Dec 18, 2008
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
websnail
  • 419 Answers
SOURCE: Waste ink full How i 'll reset my printer epson dx4450
Sorry to say that there isn't currently a confirmed reset utility available on any of the usual sites...
The only POSSIBLE option I found that MIGHT work is the CX5600/DX4400 adjustment utility from 2manuals
Best of luck and hope you find a usable solution.
Posted on May 06, 2009
Service required software
Service required mean waste pad full/almost full. You have to reset waste ink counter. But, you have to replace the pad. or just extend the outlet pipe from head cleaning mechanic to outside of printer.
Browse/googling for R230 resetter/adjusment program. Reset waste ink counter. indoreset.blogspot.com
Sep 30, 2013 | Epson STYLUS R230 InkJet Photo Printer
What is ink pad
Ink ped means when your printer working start or when the printing end or when you cleaning your head some ink is waste and that ink move with in a motor and drop down a ped which is called waste ink pad when it is full your printer is not working. when you reset this it rework
Aug 19, 2013 | Epson Printer
INK PAD FOR MY EPSON ME320
where i can find the reset button of epson me 320 printer?
Jan 10, 2012 | Epson Office Equipment & Supplies
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Both the red and green light are on and blinking.What is wrong with my Epson C60?
kiryakitsa1 You should download the SSC Service Utility as pineworks says. Read the instructions and warnings. Go to Reset counter protection and press reset. You may recieve a warning about replacing your waste ink pads. I have always reset the protection counter without replacing the waste ink pads and I have never had a problem. If you see ink drainage then you should replace the waste ink pads and then reset the protection counter. I have never had a problem with ink heads and I have done this many times.
Feb 07, 2010 | Epson Stylus C60 InkJet Printer
Printer has ink BUT has stopped printing
It is your print head, not ink cartridge
It is reasonably easy to change yourself - google for Stylus C70 printer head
Aug 05, 2009 | Epson Stylus C70 InkJet Printer
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
EPSON STYLUS C43SX PRINTER
You need to reset the waste tank or the counter to resolve the problem.
If your C42 blinks both lights and displays a message to the effect that parts inside your printer have reached the end of their servicable life, then you probably need to clean the waste ink pads. These pads collect waste ink whenever the printer cleans it's heads. The printer counts how much ink it thinks is in the waste ink pads and refuses to print when they are full.
To verify whether this is the case, download the "SSC Service Utility" from http://www.ssclg.com/epsone.shtml.
http://www.ianwillis.co.uk/c42/
Mar 26, 2008 | Epson Stylus C43SX InkJet Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus Photo 750 InkJet Printer Logo
219 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
