Question about Optoma EP716 Multimedia Projector
Optima ep716 power light flashes green but cannot turn on projector?
Opened the unit and it appeared clean and dust free, no obvious loose connections. Bulb appears fine, no broken filament. Closed it back up, plugged it in, all it does is flash green on the power light on top, no fans kick in or anything else. Any ideas?
    Genius:
  • 1,212 Answers
The green flashing light is jsut indicating it is in standby mode.
Just double check the connectors are in place and do not have any damaged pins. If the input is active from a laptop- make sure you have the external monitor enabled- some you have to manually enable, some you merely need to have the monitor plugged into it.
If all of that is okay and functioning, and it still will not get out of standby, open the unit and check the wiring to the DB15 connector for a broken wire, If those check out, visually inspect the power supply for any bulging electrolytic capacitors- if any are found, replace them with high ripple current types.
Posted on Feb 07, 2012
4 Suggested Answers
SOURCE: EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Posted on Jan 03, 2009
projdoc
  • 2237 Answers
SOURCE: I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Posted on Nov 16, 2009
ViscamTech
  • 528 Answers
SOURCE: just purchased a refurbished optima ep716
Reduce the screen resolution of your computer monitor to 800 x 600 and check. Let us know the result.
Optoma is a SVGA projector. i.e. the maximum resolution supported by your projector is 800 x 600.
Posted on Sep 26, 2011
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Just purchased a refurbished optima ep716 projector won't synch-keeps rolling through search mode - I have it connected using the SCART setting.
Sep 26, 2011 | Optoma EP716 Multimedia Projector
I neet a colour wheel for an EP716 and calibration instructions. thanks
My 716 when I turn it on after 3/4 minutes the images turn green and then it turn offf
Mar 22, 2011 | Optoma EP716 Multimedia Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Oct 22, 2009 | Optoma EP716 Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 turns on but no picture displays
Don't ever just unplug the power cord while it is on. The bulb needs to cool down with the fan still on.
Did you ever connect a source?
Sep 17, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 Multimedia Projector Logo
253 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
