Question about Irons
Russell Hobbs Steam Glide 2200 won't produce steam.
The base unit is making all the right noises but the steam is not coming through to the iron. Have tried changing filter. The lead from the steam unit gets hot but nothing comes through.
  • 1 more comment
  • julieslaw Nov 19, 2008
    i have the same problem that it is pumping but not steaming, the red light is flashing, will putting limesclae remover in the water tank help?
  • 1074437 Nov 28, 2008
    Ours ran out of water, so I switched off, refilled the tank and restarted. From that point on, the water appears to heat up but the pump refuses to start and no steam is produced. I read a review on Amazon which said that Russell Hobbs had suggested that the inability to produce steam might be due to an airlock, so as described I have changed the filter, put the iron below the level of the base unit, then put the iron higher than the base unit, and I've switched off for 20 minutes, but still no joy. Since I have lost the instruction booklet, I don't know what to do now. Any help will be appreciated.
  • Anonymous Mar 20, 2014
    I have steam coming from the bottom of the reservoir of my steam generator iron it is a Russell Hobbs 18456 steam generator iron
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Posted on Dec 17, 2008
Scot8boy's solution worked well.
The symptoms on my iron were similar - iron not heating up (and no orange light on the iron). Just for clarity, the pump is at the front of the base unit (not the iron). I did not have to replace the spring - simply taking it apart and putting it all back together was sufficient.
Thanks Scott
Posted on Dec 20, 2009
I followed Scot8oy's advice and removed the pump. The spring wasnt broken so I put it back together and it now works. Maybe the pump was just sticking but its done the trick so thank you!
I would however reitterate Scots last point. The insides of the iron get very very hot. As Terry Wogan would say " See the blisters "
Posted on Oct 05, 2009
  • 341 Answers
Fill with limeaway let it sit for about 2 hours.. empty.. fill with water
Posted on Oct 22, 2008
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Aug 10, 2009 | Irons
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
No steam from russell hobbs steam glider iron. replaced filter
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Jan 04, 2009 | Applica Steam N Glide WSI750 Iron
Irons Logo
1,117 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
