Question about Dryers
I need the mounting bracket that attaches to the cieling and then the fan motor PQC-A encon for motor PQC-M
SOURCE: Fan Parts Hunter Fan Type C Model 25436 No. 017626
i have a hunter ceiling fan p/n 23457 i need the receiver 85112-02-000
can you help
Posted on Oct 25, 2008
  • 25 Answers
SOURCE: Cover does not attach to the universal bracket I purchased
Buy a drill and drill bit and make a hole in the bracket where needed. To make installation easier, use a larger that needed drill bit and add washer to screw, won't look as professional but you are not a professional anyway. Who goes around looking at ceiling fan mounts anyway???
Posted on Jan 15, 2009
  • 9 Answers
SOURCE: i need a celing mounting bracket for 52in 5 blade
home depot!
Posted on May 23, 2009
jvernice
  • 63 Answers
SOURCE: the fan motor/bracket that attaches to the
Call Hunter (800)893-9330 for a new bracket. They should replace the damaged bracket for free or a nominal fee. They have a potential liability if the bracket is defective. If you broke it, that's another story.
Posted on Jul 29, 2009
GeneratorDan
  • 44 Answers
SOURCE: I need to find the part that is screw to the
Go to home depot ,menards or lowes they should have that mouting bracket your looking for most of those are universal. Hope this helps
Posted on Nov 06, 2010
How do I remove fan mounted close to ceiling?
There should be side mounting screws in the canopy which attach it to the mounting bracket. The screws are removed to allow the canopy and motor assembly to drop down free of the mounting bracket. A convenient hook is provided to allow wires to be disconnected.
Oct 23, 2015 | Hunter 20461 Brushed Nickel Ceiling Fan
How do you mount the cieling fan
Put the hanging bracket on the electrical box. Assemble fan top with rod & canapy & hang on bracket. Wire fan & connect blades and bottom cover.
Aug 19, 2014 | Kichler Lighting Dryers
I need to find the part that is screw to the ceiling in which the fan needs to be attach to ,for encon model M52-5B/3L please!
Nov 05, 2010 | Encon Industries (78018) Ceiling Fan
I have a ceiling mount Encon fan/light. While trouble shooting, I found that the motor capacitor had "opened", and the sides of which had blown outward. I want to get a new capacitor. The model is:...
You don't need those particular models of capacitors, all capacitors with those characteristics (.2 and .4 microfarad at at least 200 volts) will do. You can find them at all hobby shops - just remove them and ask for a similar one.
Jul 04, 2010 | Encon Industries Dryers
The fan motor/bracket that attaches to the mounting bracket is broke and i would like to know if this can be replaced
Jul 29, 2009 | Hunter 20347 Ceiling Fan
I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
Jan 13, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Where do i put remote reciever for fan install.
I'm not completely sure what the fan mounting bracket (that screws to the electrical box) looks like on this model, and I'm not sure what type of remote you have, but remote receivers usually slide in between the ceiling and that bracket (slide in with antenna wire first). Or the other type goes inside the very bottom of the fan, the part where a light kit gets attached (these receivers look like a donut).
Jan 08, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Optoma projecter
It is most likely getting too hot.
Make sure all the fans are clean. Make sure the projector is not mounted too close to the cieling. This may block vents in the housing.
If you have to, you may need to mount a small fan near the projector to blow into the vents. Make sure it blows in the right direction. You don't want it working against the fans inside the projector.
Just for a test, unmount the projector and run it on a table. This should tell you if the mount on the ceiling is causing the problem.
Aug 29, 2008 | Optoma H30 Multimedia Projector
Dryers Logo
48 people viewed this question
Top Dryers Experts
