Question about Dishwashers
Used wrong soap and it stop
Used liquid soap and it stopped
    President:
  • 2,468 Answers
Your flood switch activated,try flushing out the unit manually,then fill with cold water from faucet as hot water from the machine will make more suds and cold water will kill suds,do this to purge unit of soap this should remedy your situation
Posted on Feb 08, 2012
  • 641 Answers
SOURCE: Continuous rinsing
Put 2 tablespoons of oil into the water at the bottom of the dishwasher it will help break up the suds. Sprinkle as well ordinary table salt liberally across the suds to disperse them. Try to drain the unit as much as possible, soaking up any residual water or suds with a dry towel. Let the machine fill again, and repeat the process if necessary. Good luck !
Posted on May 25, 2006
  • 1462 Answers
SOURCE: Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Posted on Apr 04, 2007
  • 1073 Answers
SOURCE: i have a kenmore dishwasher.
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Posted on Apr 10, 2008
onthejob5130
  • 640 Answers
SOURCE: my kids used dishwashing liquid in their grandmothers dishwasher
fabric softner or bleach,,,also open dishwasher berfore you start it and fill with a pot of cold water,,the hotter the water the morev suds you will get,,onthejob
Posted on Jan 21, 2009
  • 677 Answers
SOURCE: the dishes come out with a white film on them.
the problem is hard water. go to www.dishwasherfilter.com they have an awesome product out to solve this problem. after one load your dishes will be spotless. very affordable and has a money back guarantee.
Posted on Dec 19, 2009
How does soap dispenser work? what does up for liquid and down for powder mean?
Liquid laundry soap (comes in plastic liquid container) uses the up. Dry powder laundry soap uses the soap that comes in a box, therefore not liquid. and uses the down switch slider control.
Apr 14, 2015 | Maytag NFW7200TW Front Load Washer
Tip
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or liquid..total... dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
Water leaking through air vent and estimated time remaining sticks during the rinse cycle
Run a tub clean cycle. No clothes. No soap. Just vinegar. About a cup.
May 03, 2017 | LG Washing Machines
Soap is not completely washing all the soap powder away.
Stop using the powdered detergent. It has a reputation for clogging up machines and pumps. ALWAYS use the liquid detergent.
May 28, 2012 | Electrolux Dishwashers
The dishes come out with a white film on them. they are not clean clear dishes, the bowls and glasses have a film. I was using cascade dry soap switched to liquid soap still have the problem. what can I do...
add Jet Dry or some other sheeting agent to the wash. also most pros frown on liquid soap (gel) so try the hard tablets, most have the jet dry built in. This also ensures the correct amount of soap. if this is a new development check the screens on the bottom of the washer under the spray arm and see if they are clogged with food or gunk. sounds like you are not getting a good rinse.
Dec 13, 2009 | Dishwashers
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
Filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
Hello chystalsbrr
Welcome,
You said you, filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
You can try by turning off the breaker in the electric box that feeds the dishwasher for 5 minutes and see if when you turn it back on and the washer resets itself, and the soap door opens.
Or push cancel and then rinse and after it is done and goes to the dry cycle stop it and it should be open.
In the use of liquid soap in both a dishwasher and or washing machine you must use less soap. Half that of powder soap.
Or the suds will roll out of your dishwasher on to your floor. And this is not a malfunction on the dishwashers part. NO bad seal or anything!
In a clothes washer it will destroy the seal and bearing in less than 5 years!
Let me know how it goes!
Huuum
Please remember to leave a rating
Oct 19, 2008 | Whirlpool Dishwashers
Soap does not desolve
I put the wrong dishwasher on my last post.
Dec 01, 2007 | GE 24 in. GSD3210Z Built-in Dishwasher
Continuous rinsing
May 25, 2006 | Hotpoint 23 in. BF41 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
