Question about Toys
Fuel trouble jcb 533-105
Can't bleed fuel system
2 Suggested Answers
  • 1207 Answers
SOURCE: Jcb 530/70 won't start.turns over fine,changed
you should check your battery at first!!!
_____________________
bmw b800
Posted on Jun 11, 2012
Bleed jcb 2cx brakes
-You mean how to bleed brake fluid...?
If so. Here is a basic to do. (Doesn't matter front or rear)
-Most car's bleeder screws fit 10mm combination wrench.
Here thing that you need:
-Wrench
-A jar (Glass or plastic. Doesn't matter)
-A Clear vinyl tubing 1/4" inside diameter by 12" to 18"
-a helper.
-A bottle of new brake fluid. (Buy the big one)
Now locate the bleeder screw, lose it then tight it back just little to prevent leaking. (Only lose DO NOT TAKE IT OUT)
-Hook up the tube to it, 1 end into the jar.
-Ask helper to press brake pedal all the way to the floor then HOLD right there and lose the bleeder screws to let the fluid come out then tight it BEFORE RELEASE THE PEDAL.
Repeat this step until you see clear fluid come out. You're done this one. Then go to the next one.
MAKE SURE CHECK THE RESERVOIR VERY OFTEN. DO NOT LET IT RUN OUT OF FLUID!!! If it has ABS YOU'LL HAVE BIG TROUBLE.
Here the fast way to do. Empty the fluid reservoir and fill new one before bleed the system.
Good Luck
Mai
Aug 28, 2015 | Cars & Trucks
Jcb telehandler 532
jack up the front wheels ,fit safety stands with engine running , move wheels from lock to lock several times to bleed out air. top up oil tank.
Aug 15, 2014 | Cars & Trucks
How do you bleed fuel system on a jcb diesel zt20d zero turn grass mower ,wont start after ran out off fuel
take the fuel filter off pour full in it put it back on changefuel filter next spray some staring fliud in it until starts keep spraying short burst to keep it running until the desil catches and motor runs on desil
Jul 12, 2014 | Garden
My 5.9 dodge cummins diesel won't start, I've replaced the fuel lift pump, and the fuel filter, turns over. But will not start?
Most likely you just have air in the lines.Crack them open one at a time and bleed them with the fuel pump off and on till you get fuel.If it fires dont hit the throttle let it sit and idle and close the line.Does it fire up with a small whif of starting fluid?
Mar 17, 2013 | 1999 Dodge Ram
Have jcb skid steer that was running and then shut down at idle. it will not restart. have plenty of battery and the starter is working fine.
Check the fuel solenoid stop control on the injection pump in case the wire's off/loose. This can be tested by a length of wire and 2 croc clips direct from the pos terminal on the batt. If it fires up, the supply via the harness is lost somewhere. It needs a supply to keep the pump running.
Bleed the fuel system, if it fires up, its drawing air into the system. Check seals/o rings on fuel filters and any loose unions.
Oct 17, 2012 | Cars & Trucks
bmw b800
Jun 11, 2012 | Cars & Trucks
Bleed fuel system
There is often a bolt on top of the diesel pump which you open up in order to bleed. You open the bolt up a few turns until it's loose then crank the engine until fuel comes out around the loose bolt. The engine should start up at the same time.
It doesn't matter if you open up a bolt that's not the bleed bolt, just tighten it up and try another bolt until you find the bleed bolt.
Apr 23, 2012 | 2005 GMC Sierra
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Toys Logo
21 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
