Question about Uniden Radio Communications
Have a uniden uniace 300 homebase cb radio
Cant pick any one up clearly and when I can it sounds like they are on a different frequency can any body help it sounds like you have skip coming in but also the meter on it does not move when you key the microphone although the red and green light changes on keying and unkeying and does any one have a copy of a manual for the wiring diagram for me please Does anyone know which pot it is that affects the needles please
5 Suggested Answers
Mechanic688
  • 204 Answers
SOURCE: wiring for echo chamber to uniden 300
Mick, check out this site, they talk about some of the same equip. as your asking about. It's a very good site.
http://www.radiomods.co.nz/forum/viewtopic.php?p=5303
hope this helps you with your search, Mechanic
Posted on Jan 27, 2008
Benimur
  • 6966 Answers
SOURCE: CB Radio
Hi and welcome to FixYa,
Have you tried VR5? Not much on the mods other than adjusting L8-10 for AM power.
Good luck and thank you for asking FixYa.
Posted on Aug 15, 2009
  • 29 Answers
SOURCE: does it have it
this radio is not manufactured with this switch installed however there are kits that will allow this to happen.
Posted on Dec 30, 2009
SOURCE: uniden 300 homebase cb radio
add on pll kit still available from some uk cb dealers, quite an easy conversion if you're ok with a soldering iron. Think it's a piggy back pll job, not 100% sure on that though.
Posted on May 24, 2010
Can any body help I just bought a cobra 29lxeu multi standard radio is there a problem with the receive on these radios as had this radio hooked up to my homebase antenna on my homebase im...
What you describe is not standard for this radio. It should receive as good as any of the others you have. Are you sure you have all the knobs and switches set right. This radio is more complicated to operate than the previous versions. I personally do not operate one of the new LXs but I do seem to recall they have a RF Gain knob. This should be turned clockwise all the way. Look through the manual. You will be surprised and some of the features the radio has you didn't know about.
Aug 18, 2013 | Cobra Radio Communications
Uniden pc76xl cb tx works good , but rx is to weak
maybe get a different or stronger antenna? this one cannot be tuned like some of them where they will pick up and reach out better
Feb 22, 2013 | Uniden Bearcat PC 78 XL CB Radio
I NEED TO KNOW HOW TO ENTER CODES INTO THE SCANNER
hi what do you mean by codes ,or do you mean frequencies ,to enter frequencies press the program key enter the frequency you want to listen too and press enter you can select different banks for different communications ,such as emergency,air traffic,marine,rescue,etc hope this helps
Jan 08, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
What radio frequency does the uk rail network use and can I pick it up using my Uniden UBC3000 xlt scanner?
26MHz is the British CB band, the USA CB band is 27MHz... http://www.wibble.co.uk/links/ukspectrum/spectrum.html
British Rail MPT1327 system. Operates nationwide on the following frequencies: 204.85, 204.9, 204.9, 205, 205.05, 205.1, 205.15, 205.2, 205.25, 205.3, 205.35, 205.4 205.65, 205.675 205.7, 205.725, 205.7500, 205.8, 205.8375, 205.85 205.9, 206, 206, 206.15, 206.25, 206.3 MHz
Mar 14, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
How do i find the FM frequency for a Connex CX-4300-300 CB radio?
FM is just a form of modulation, not an actual frequency. The frequency doesn't change between any of the modes (LSB, USB, AM, FM, CW).
For example, if you are on channel 19 (27.185MHz) on AM (Amplitude Modulation,) switching to FM (Frequency Modulation) mode you would still be at 27.185MHz, but using a different form of modulation.
Nov 10, 2009 | Connex CX-4300HP CB Radio
Uniden 300 homebase cb radio
would love to add mid band through pll how do i do this
Mar 24, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Wiring for echo chamber to uniden 300
Nov 18, 2007 | Radio Communications
I can't pick up anything...
Hello even though everything is connected properly, have you checked for standing waves on the antenna to radio connection? Also you may have to perform a sensitivity test on the unit. The problem is you need a RF generator for that. Set you RF generator to the frequency that is equal to the CBs middle frequency and modulate the CW with 1KHz at 50% modulation, tune to the middle of the CB band on the radio and set the output of the RF generator to .1uv and loosely couple the signal to the CB antenna with a loop of wire. Your CB should be picking up a 1KHz tone gradually turn the power level down and when the tone cuts off that level is cutoff level, then increase the level until you can hear the tone again when the tone cuts on that value is the sensitivity of the unit. Compare the measured value to the value in the owners documentation. if the sensitivity is low this could denot a problem in the RF/IF section of the CB.
Oct 04, 2007 | Uniden Bearcat Pro PC68LTW 40-Channels...
Radio Communications Logo
220 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
