End-to-end loop delay specification of ISDN terminals
  • 634 Answers
Disconnect the coaxial cables from the transmitter and receiver of your equipment. They may be marked "Output" and "Input."Connect the jumper cable from the transmit jack to the receive jack. This completes your near-end loopback--and, if everything works, the equipment should communicate with itself.Connect the two cables that you disconnected from the equipment together with the coaxial splice. The completes the far-end loopback and the distant equipment should be able to communicate with itself.Restore the cables to their original positions after you complete the test.
Posted on Feb 08, 2012
The door retract spring has broken what is involved to replace it M/c new in Nov2008
Usually removing the bottom panel, side panel or rear panel.
Unhook the old one. Attach a loop of very strong string to the loop on the other end and stretch it to the other fixing closest to you. For safety wear goggles.
Google
make model spares
you will end up on a site like this
http://www.reliableparts.ca/catalog/Dishwasher-Parts
and specifically, like this with a parts diagram. NOTE: this may not be the part for YOUR machine.
Dishwasher Door Spring
Nov 24, 2015 | Dishwashers
Anyone have a wiring diagram or know how to hook this up ?
Black and red are pretty standard for negative & positive battery terminals.
There is likely a model number (pic isn't good enough to see the finer print) on the label but the larger numerals are probably serial numbers and without the model number, you may have a problem finding the exact installation info you want.
The link below has illustrations for a different model but manufacturers will generally stick with a wiring code to make installation and even production simpler:
http://www.mygen.com/users/dbruce/myz31/Jacobs%20Ultra%20Team%20Installation%20Instructions.pdf
That company does not have the web 'presence' they should have by now.
Apr 20, 2015 | Cars & Trucks
I am running rca cables to my amplifier. The little black wires that are wound with the rca cables which have looped terminals, Are they supposed to be connected to a ground?
Yes you can connect these wires to ground
this is used to prevent "Ground Loops" (un-even ground points in the system)
un-even ground points cause engine whine noise in the system and by connecting the stereo and amplifier grounds together usually resolves this issue..
So just connect one end to the same ground as the stereo and the other end to the amplifier ground location..
Hope this info helps
May 20, 2011 | Car Audio & Video
Can not remove element
just lift the loop part and then pull out, away from the two end parts...the element will just slide out...it may take some force to get it to release...you may have to hold onto the plug end and pul it apart one terminal at a time...
heatman101
Apr 23, 2010 | Ovens
How to convert infix to postfix using stacks in java programming?
u can try the follwing coding
import java.io.*;
import java.util.*;
//begin coding for the stack interface
interface Stack<E>
public boolean isEmpty();//tests is current stack is empty. Returns true if so, and false if not.
public E top() throws StackException;//retrieves value at the top of the stack. Stack cannot be empty.
public void push(E value) throws StackException;//pushes a value on the top of the stack.
public void pop() throws StackException;//removes a value from the top of the stack. Stack cannot be empty.
}//terminates coding of Stack interface
//begin coding for the objArrayStack class
class objArrayStack<E> implements Stack<E>
//constructor
public objArrayStack()
topValue=-1;
}//terminates constructor
public void push(E value)throws StackException
if(topValue<ArraySize-1)//currrent stack is not full
++topValue;
Info[topValue]=value;
}//terminates if
else //current stack is full
throw new StackException("Error: Overflow");
}//terminates push method
if(!isEmpty())//current stack is not empty
--topValue;
else //stack is empty
throw new StackException("Error: Underflow");
}//terminates pop method
return topValue==-1;
}//terminates isEmpty method
if(!isEmpty())//stack is not empty
return (E)Info[topValue];
}//terminates top method
//declare instance variables
final int ArraySize=10;
private Object Info[]=new Object[ArraySize];
private int topValue;
//begins coding for the StackException class
class StackException extends RuntimeException
//constructor
public StackException(String str)
super(str);
}//terminates text of constructor
}//terminates text of StackException class
//method to convert from infix to postfix notation
public static String InToPost(String infixString)
//operator stack initialized
objArrayStack<Character> operatorStack = new objArrayStack<Character>();
//postfix string initialized as empty
String postfixString = " ";
//scan infix string and take appropriate action
for(int index = 0; index < infixString.length(); ++index)
char chValue = infixString.charAt(index);
if(chValue == '(')
operatorStack.push('(');
else if(chValue == ')')
Character oper = operatorStack.top();
while(!(oper.equals('(')) && !(operatorStack.isEmpty()))
postfixString += oper.charValue();
operatorStack.pop();
}//end while loop
}//end else if
else if(chValue == '+' || chValue == '-')
if(operatorStack.isEmpty()) //operatorStack is empty
operatorStack.push(chValue);
else //current operatorStack is not empty
while(!(operatorStack.isEmpty() || oper.equals(new Character('(')) || oper.equals(new Character(')'))))
}//ends while loop
}//end else
}//end else if
else if(chValue == '*' || chValue == '/')
else
while(!oper.equals(new Character('+')) && !oper.equals(new Character('-')) && !operatorStack.isEmpty())
}//end while loop
}//end else
}//end else if
else
postfixString += chValue;
}//end for loop
while(!operatorStack.isEmpty())
if(!oper.equals(new Character('(')))
}//end if
}//end while
return postfixString ;
}//terminates text of InToPost method
public static void main(String[]args)
objArrayStack mystack = new objArrayStack();
System.out.println("Enter a string");
Scanner scan = new Scanner(System.in);
scan.nextLine();
String str = scan.nextLine();
InToPost(str);
}//terminates text of main method
}//terminates text of objArrayStack class
Mar 16, 2010 | Sun Java Programming Language (cdj-275)
Routing dryer belt for kenmore 11060702990
rap the belt around the drum ribs down,if you get your pants belt and fold it in half and pinch it around 4 inches from the folded part that's how the belt will look when it goes around the pulley, your fingers are the pulley and the loop that's on the end goes onto the motor,pinch the belt together and the loop that's left on the end goes onto the motor
Mar 13, 2010 | Kenmore Dryers
A downlight transformer has failed it is a 20-105w/va & the primary wires black & red come out the same end as the secondary wires -these are a black &red & 2 others to the light. On the...
your new transformer should be fine unless your downlight lamp is 20w,most are 50w 12v so you should check this first.
As for connection your mains supply (primary) connects red to either of the 2 live terminals and black to any of the neutral.The 2 wires from your lamp then go into any pair of the secondary terminals.polarity doesn't matter that is why they are not marked.The transformer can supply 105 w so 2 50w lamps may be connected.
HTH
Oct 27, 2009 | Kitchen Appliances - Others
What type of powercord and outlet does this dryer require? Electrician installed a 220 outlet.
ELECTRICAL REQUIREMENTS
ELECTRIC Dryer
CIRCUIT - Individual 30 amp. branch circuit fused with 30
amp. time delay fuses or circuit breakers.
Use separately fused circuits for washers and dryers, and DO
NOT operate a washer and a dryer on the same circuit.
POWER SUPPLY - 3 wire or 4-wire, 240 volt, single phase, 60
Hz, Alternating Current.
POWER SUPPLY CORD KIT - The dryer MUST employ a 3-
conductor power supply cord NEMA 10-30 type SRDT rated at
240 volt AC minimum, 30 amp., with 3 open end spade lug
connectors with upturned ends or closed loop connectors and
marked for use with clothes dryers.
WARNING – Risk of Shock. Appliance grounded to neutral
conductor through a link. Grounding through the neutral link is
prohibited for (1) New branch circuit installations (2) mobile
homes; (3) recreational vehicles; and (4) areas where local codes
do not permit grounding through the neutral, (1) disconnect the
link from the neutral, (2) use grounding terminal or lead to
ground appliance in accordance with local codes and (3) connect
neutral terminal or lead to branch circuit neutral in usual manner
(if the appliance is to be connected by means of a cord kit, use
4-conductor cord for this purpose). USE COPPER CONDUCTOR
ONLY. The dryer MUST employ a 4-conductor power supply
cord NEMA 14-30 type SRDT or ST (as required) rated at 240
volt AC minimum, 30 amp., with 4 open end spade lug
The complete installation manual is at ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134917700es.pdf
Jan 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
Reprogramming
Open Internet explorer and type the ip address of the router in the address bar and hit enter. (it should be 192.168.1.1) The setup page for the router should open. Click "Advanced" then click "ISDN Configuration" then click "ISDN Parameters" You can enter the new SPID's the phone company gives you there. Good Luck, El Duderino
Nov 15, 2006 | Ramp Networks WebRamp 410i (516S)...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
