Question about Car Audio & Video
Watson CRC8448MU
The USB do not read and appears ERROR 13
  • Anonymous Jan 03, 2009
    tengo el mismo problema. el usb me da error 13. he probado con fat, fat32 y ntsc y no se soluciona.
  • Darcky_demon Feb 03, 2009
    my cd player dosen't reed my usb
3 Suggested Answers
SOURCE: USB stop working
Use the Aux in cable with an ipod. Works great so far......
Posted on Dec 24, 2007
SOURCE: i have a watson CRC8448MU
eror 12 when I put mem card
Posted on Jun 30, 2012
I was having a Watson Client problem... and today I get: Exc in ev handl: Error: Bad NPObject as private data! What's up with this, now! Still having Watson Client problem and can't open Word! Help
This is a virus ..I suggest to reinstall the program ..and remove the old one completely ..If this will not fix the issue you will have to reinstall operation system to fix it for good.
Dec 24, 2011 | Computers & Internet
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
When i try to shut down my computer a blue screen appears with an error report : stop:c000021a {fatal system error}
This is the cause:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
If possible contact a local technician to the do the below,if you are not sure of this process.
and also ask him to take a backup of your registry keys and create a system restore point without fail.
To troubleshoot this problem, you must determine which of these processes failed and why.
To determine which process failed, register Dr. Watson as the default system debugger (if it is not already the default debugger). Dr. Watson for Windows NT logs diagnostic information about process failures to a log file (Drwtsn32.log). Also, you can configure this program to produce memory dump files of failed processes that you can analyze in a debugger to determine why a process fails.
To set up Dr. Watson to trap user-mode program errors, follow these steps:
  1. At a command prompt, type System Root\System32\Drwtsn32.exe -I, and then press ENTER.
    This command configures Dr. Watson as the default system debugger.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options: Append to existing log file
    Create crash dump
    Visual Notification
  3. After the computer restarts from the STOP 0xC000021A error, run Dr. Watson (Drwtsn32.exe).
  4. View the Dr. Watson log to determine what user mode process may be causing the problem.
  5. If the Dr. Watson log does not contain sufficient information to determine the cause of the problem, analyze the User.dmp file to determine the cause of the STOP 0xC000021A error.
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 (http://support.microsoft.com/kb/241215/ ) How to use the Userdump.exe tool to create a dump file Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
    Note Most STOP 0xC000021A errors occur because Winlogon.exe fails. This typically occurs because of a faulty third-party Graphical Identification and Authentication (GINA) DLL. The GINA is a replaceable DLL component that Winlogon.exe loads. The GINA implements the authentication policy of the interactive logon model. The GINA performs all identification and authentication user interactions.
It is very common for certain types of remote control software to replace the default Windows GINA DLL (Msgina.dll). Therefore, a good first step is to examine the system to see if it has a third-party GINA DLL. To do this, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Value = GinaDLL REG_SZ
  • If the Gina DLL value is present and if it is anything other than Msgina.dll, it probably means that a third-party product has changed this value.
  • If this value is not present, the system uses Msgina.dll as the default GINA DLL.
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Click Start, and then click Shut Down.
  2. Click Restart, and then click OK.
  3. Press F8 at the indicated time:
    • For an x86-based computer: When a screen of text appears and then disappears , press F8. (The screen of text may include a memory test, lines about the BIOS, and other lines.) There may also be a prompt that tells you when to press F8.
    • For an Itanium architecture-based computer: After you make your selection from the boot menu, press F8. There may be a prompt that tells you when to press F8.
  4. Use the arrow keys to select Last Known Good Configuration, and then press ENTER.
    NUM LOCK must be off before the arrow keys on the numeric keypad will function.
  5. Use the arrow keys to highlight an operating system, and then press ENTER.
Dec 23, 2010 | Computers & Internet
Jit debugging problem. I have tried disabling the script debugging on internet and other. This didn't solve the problem. Any other suggestions ?
I was just reading the thread! Kinda hilarious though.
JIT is used to catch real time errors especially run-time. It is very useful for developers. To catch un handled exceptions.
Jit comes as a part of Visual Studio. If you do not know how to manage Jit its better not to install Visual Studio (no skills to manage it will give you lots of trouble). Just the programing skills does not make a good developer. Well its not a fault of VS developer team or Bill Gates. Doh!
Jit will be invoked if enabled by Visual studio, instead of Dr Watson. If programs crash the crash handlers will be invoked and you will see Dr.Watson process running in the background. It will call dumprep and will create error logs; Errors will be logged in Event Viewers as well. Even a simple failure will be handled and Jit will be invoked. So programs will begin to crash while they run or install.
Some developers set programs to use Jit and Jit will be enabled instead of Dr.Watson. Dr.Watson will be invoked in serious errors however. Its obvious. But specially if you have installed Visual Studio, you will be using JIT as well. JiT overrides the Dr.Watson Program. But you can reverse it back using two methods.
Its a third party piece however. I wonder why these MSDN people do not know how to provide a complete answer. Each and every person does not understand Administration of programs. So its their responsibility. That is a laughing matter though. But people will be pissed off. Can't blame them either. Some of them are not familiar with regedit tools. So the answers have to be flexible and complete.
The bad behavior of JIT is it will suspend the program an once when an error occur. You will never be allowed to run further. So its kinda piece of ****. It also has security issues with it.
Unfortunately if a program Invokes JIT intensionally its not possible to reverse the process.
Stop JIT while you have Visual Studio installed (Its a stupid thing to uninstall it without removing JIT. No way!)
How this thing will be enabled?
  1. Open VS:
  2. Go to Tools and then Options.
  3. In the Options Dialog box Double click Debugging and then click JIT
  4. Enabling options:
  • Manage
  • Native
  • Script
Click on OK.
This sets the Registry key and will start JIT. So do the Revers to Disable it.
You have to Disable the Keys. Method one:
  1. Click on Start Menu and Type Run (for P Hit Run box)
  2. Type in regedit and hit Enter
  3. Expand the Keys to located the place
  4. HKLM\Software\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger is one location.
  5. HKLM\Software\Microsoft\.NETFramework\DbgManagedDebugger
  6. Delete these keys. Or set the Auto key's value to 1.
  7. On a 64bit system the paths will be: HKLM\Software\Wow6432Node\Microsoft\...
  8. You may need to reboot the system as well.
Method two: Enable Dr.Watson using an alternative method:
  • Get a Command Window (Command Prompt)
  • Type drwtsn -i and
  • Hit enter
If you were using a third party debugger read this Microsoft Support
Next step
Open Start>Control Panels>Internet Options: Advanced and activate (check box)
  • Disable Script Debugging (Internet Explorer)
  • Disable Script Debuggung (Other)
If you have enabled Server Side Script Debugging the pages will freeze if an error occurs. Read the enabling procedure. Steps to enable debugging portion. Do the Reverse to disable it.
For Script Debuggers: Here is how you enable the JIT:
  • Click on Options then Tools
  • Click on Debugger
  • Select JIT debugger and attach to programs running on this machine
  • So now you know how it happened. Do the reverse to disable it!
Using third party tools and software may enable this tool. If you detect one you have to avoid using it. Just posted this in the MSDN thread as well.
Please rate the answer as well! Feel free to contact if you have further issues.
Thanks for using Fixya! -Lasitha
Jul 09, 2010 | Computers & Internet
Help me
sounds like the program dr. watson is corrupted. Go to the control panel and add/remove programs and delete dr. watson. Its a utility program that is not essential
Aug 14, 2009 | Microsoft Windows XP Professional
The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb...
Hello I have the same problem but no body do answers . Maby we change radio {panasonic or oder :-). The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb key along with music files in mp3 & W4ma types though we still can't seem to get the Tevion 5705 car radio to read the music from the usb key when inserted. We keep getting an 'Error 13' message, can someone please help . my email : zadychladislav@hotmail.com Ladi
Aug 13, 2008 | Car Audio & Video
USB stop working
Dec 20, 2007 | Boss 634UA CD Player
Vrcd400-sdu error code 13
does your usb device use batteries,some device require.
Aug 22, 2007 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Car Audio & Video Logo
1,517 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
