Question about Sewing Machines
SINGER sewing machine:STUCK/ whirring sound... What should I do TO FIX PROBLEM?
MACHINE JAMMED. Foot stuck in place. Whirring sound from TOP right side of machine . HAVE REMOVED ALL TREAD that was jammed by bobbin. Needle IS NOT bent.
  • Sewing Machines Master
  • 7,365 Answers
It sounds like the machine needs to be serviced
Posted on Feb 08, 2012
  • 192 Answers
SOURCE: Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Posted on Nov 14, 2007
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
SOURCE: Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Posted on May 01, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
I was attempting to pick up the bobbing thread, before sewing. The needle is now stuck in the down position and the handwheel is unresponsive but the motor is whirring when foot pedal is depressed.
Do not press the foot pedal. Continuing to run the motor when the machine cannot work properly could irreparably damage the motor. Unplug your machine. Cut the top thread at the needle, open the bobbin area and try to remove the bobbin case. You may have to patiently snip tangled threads, but eventually you should be able to get the bobbin case out. Once that happens, the needle will most likely be free.
Jun 22, 2017 | Sewing Machines
Needle shaft stuck. Machine won't work.
It's possible that you have threads wound somewhere inside the machine. Likely places are the tension unit and near the hand wheel.
Sep 17, 2015 | Singer 6038 Mechanical Sewing Machine
Sewing machine hand wheel won't turn. Fabric is stuck under needle. How do I fix this?
Mine has only done this when the machine has jammed with thread form the bobbin and the top thread not being threaded properly in machine or the machine is dirty and needs to be brushed to remove all the fuzz from sewing. Pull the pressure foot off of the machine. Use a seam ripper and carefully cut the threads that are wrapped all around it. Once it is loose, take it off of the machine, then you will be able to pull your bobbin from the machine and trim all the thread that is wrapped around it. Then use a toothbrush or sewing machine brush and clean your bobbin area of your machine with the brush and try it again.
Feb 28, 2015 | Singer Sewing Machines
Inspir model bobbin
a part inside the sewing machine could have come loose or broken it would be a good idea to have the sewing machine checked..
Aug 05, 2013 | Singer Inspiration 4205 Mechanical Sewing...
Singer 2662 Needle doesn't move
when was the last time the machine was serviced?
Apr 11, 2012 | Sewing Machines
Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
Mar 18, 2012 | White Sewing Sewing Machines
Sewing Machines Logo
78 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
