Question about Philips Senseo HD7832 Coffee Maker
I have Philips Senseo SL7832 Coffee Maker and all the lights just stopped working. How do I fix it?
There is a LCD screen on the top and three buttons on the bottom and one day they all stopped working. The coffee maker still works and you can read the LCD screen at the top but there is no back lighting. Because all the lighting went at the same time I would think it is something simple but I see no way to take it apart so I am stuck. Any ideas would be appreciated. Thanks
  • 5 Answers
SOURCE: stuck senseo maker
Your machine has been locked because there is too much pressure inside the machine. Unplug it for about 24 hours and leave it with the lever up. After that it should come open. Carefully clean out the tiny nozzles to make sure there isn't any loose coffee hanging out in there. This happens if you make your own pods. Just be grateful that it didn't explode all over your kitchen!
Posted on Mar 05, 2008
  • 5 Answers
SOURCE: Senseo coffee maker
There isn't a way to adjust it. The senseo is calibrated to make either a 4oz or 8oz cup. Unfortunately, we are so used to buying mugs at the store that are MUCH bigger than this!
  • 4090 Answers
SOURCE: how do you take apart a senseo coffee maker
2 words! With difficulty
Posted on Aug 17, 2009
MsMithra
  • 79 Answers
SOURCE: I live in a limestone area and the flow through my
Believe it or not, vinegar is a blessing for cleaning nearly anything out of your coffee maker.
Fill your water reservoir 1/4th full with vinegar, then fill it the rest of the way up with water.
Run the coffee maker, then let it sit for about 10 minutes. Pour the mixture back in to the reservoir and run it again. Let it sit another 10 minutes.
Dump the mixture and use plain water this time. Let it sit for another 10 minutes. Dump the water, then repeat with clean plain water.
Wash the filter basket and pot with hot soapy water. If the vinegar smell is still present, just run it again with plain clean water.
Posted on Oct 10, 2009
SOURCE: senseo coffee maker
http://www.eserviceinfo.com/downloadsm/19109/Philips_Senseo%20HD7810/10.html
OK above is a service manual, this is what the techs use to fix, it. Use the exploded diagram,and troubleshooting guide, and you will no doubt sort it very quickly.
http://www.devicemanuals.com/guide/Home%20Appliance/Philips/Philips-SENSEO-Coffee-Maker-HD7810-75-54-User's-TXpBNE1qTT.html
Download the user manual above.
Posted on Apr 03, 2010
Who sell a three way valve for a senseo 7814 coffee maker
You may be able to get one from an appliance parts supplier or directly from Philips.
Jul 15, 2014 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD7810 /40 stops midway brewing
This lookes like a problem I experienced with another model of the Senseo. The problem here was the 470nF X-capacitor in the capacitive power supply. (230VAC models) Try replacing.
Aug 15, 2013 | Philips Senseo HD-7810 Coffee Maker
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee maker
Apr 03, 2010 | Philips Senseo HD-7810 Coffee Maker
My senseo coffeemaker has stopped pumping hot water through the coffee pods. What do I do to fix it?
When was the last time you clean it with vinegar? Run vinegar through it and you will see hard water scales that were built on the heater. Coffee makers should be clean out every month then with 2 rinse cycles after that.
Jan 24, 2010 | Philips Senseo HD-7810 Coffee Maker
Senseo HD7832 Calc Cleanup
This model of Senseo suggest cleaning once every 3 months, preferably 4 to 6 times a year.
I suggest to download the user manual from Philips for your model and to follow the procedure described.
Jun 12, 2009 | Philips Senseo HD7832 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Hello, I have a Senseo HD7842/00 (Alu) coffee machine, which still physically works, but for some reason none of the lights come on any more. The small LCD screen is no longer back lit (used to light up...
Connections on circuit board are no good.
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 26, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee problem
The pod holder has an O ring to seal the black plastic disc in,if it is not sealed you will end up with more volume and a weaker coffee without the foam,either knock the disc out and try and seat the O ring and then knock it back in or buy a new pod holder,I had this same problem
Nov 30, 2007 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD7832 Coffee Maker Logo
110 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
