Question about Phil & Teds Baby Gear
P&t front wheel sticks
The front wheel of my P&T sport gets stuck at an angle which prevents me from pushing it. How do I stop this and what type of grease/oil should I use on the joint?
    Scholar:
  • 78 Answers
Dear Jo B,
Have you made sure that none of the fixing bolts or bearings that hold the wheels in place are stuck or seized? If they are not, then you might need to adjust any of the retaining springs that also fix the wheels to the rest of the stroller assembly (if these springs are indeed fitted).
Any bearing grease, or even car axle/ CV joint grease will do fine.
Some of these strollers also have a clip that you push down with your foot and it locks the wheels in certain positions. Check that this clip is not broken or misfitting, also check the brake bar too.
Hope this helps and do let me know how you get on.
Yours sincerely
Ouszen
Posted on Feb 07, 2012
Are the back tires or axle bent from factroy to make it look like the wheels are bent on a 3 wheel bike
I assume you are referring to push bikes where the rear wheels are at an angle to the road. The axles are fitted to the frame at an angle and this is done to give them more grip when they go fast around corners. If you look at the front wheels on race cars you will often find them the same. Sports wheel chairs are also the same. It is done by design.
Jul 08, 2017 | Motorcycles
When in 'swivel' mode front wheel turns wildly making it difficult to control and even stops the buggy when the wheel 'stick' at right angles to the buggy
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
Dec 20, 2015 | Regal Lager Phil & Teds Sport Buggy Double...
I can't fold my caddytek lite 11.5 v2 cart
I'm sure you figured this out by now, but for others stuck with the same question, here's how you fold it: the upper handle of the cart is 'locked' into place with the lower cart just above the upper bag strap. It's the same plastic piece that adjusts the angle/position of the handle. Slide this plastic piece back up the shaft (toward the ball holders), and the upper handle will release & fold down. The 2 side wheels also fold in at the same time.
Jan 21, 2013 | Caddytek CaddyLite 11.5 v2 Deluxe Push...
I have an ariens zoom 1540 hydrostatic mower. One wheel turns the other does not.
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered.
Jun 11, 2010 | Ariens 34 In. Zoom Series Riding Mower
Ihave 01 sporttrac my 4wheel drive use 2 lockin 4 wheel high only that stopped working and then the back window stopped working any suggestions?
most likely the 4x4 shift motor is not working need to bring it to a repair workshop. rear window regulator sometimes get stuck try someone to push the switch while you tap the motor lightly
Feb 05, 2010 | 2001 Ford Explorer Sport Trac
Phil & Teds front wheel locked and won't budge
you should be able to pull the knob out and turn it to the possition spray some lubricating oil first if it stuck. But it will pull out. Go to www.buggypitstop.co.uk if you need any spare and advive on how to fit your pushchair
Feb 02, 2010 | Regal Lager Phil & Teds Sport Buggy Single...
Just bought the Dash. I feel that it pulls when you walk. Also having trouble with front wheel when in the swivel position. It will swivel one way but when you try to push/pull the stroller to line the...
One or more wheels may be crooked, either the axle is bent or there's the manufacturer defect. I would call the store you purchased it from to see if they can warranty the repair or replace any faulty parts.
(Personally for the price I don't recommend Phil & Ted's stroller as there are far better make & models out there that won't have such issue. I don't want to discourage you but that's been our experience with these strollers)
Nov 06, 2009 | Regal Lager Phil & Teds Sport Buggy Double...
What are the front toe in parameters for Hyundai Tucson?
Wheel & Tire
Wheel alignment
Front
Rear
Dimension
Toe-in
Camber
Caster angle(to ground))
King pin angle
King pin offset mm(in.)
Side slip mm(in.)
P215/65R16
0°±0.2°
0°±0.5°
3.53°±0.5°
12.77°±0.5°
-9.73(0.383)
±3(0.118)
P235/60R16
0°±0.2°
0°±0.5°
3.53°±0.5°
12.77°´±0.5°
-10.41(0.410)
±3(0.118)
P215/65R16
0.37° ~ 0.41°
-0.92°±0.5°
±3
P235/60R16
0.37° ~ 0.41°
-0.92°±0.5°
±3
Wheel
Size
Run out mm(in.)
AL wheel
6.5JX16
Radial : 0.3(0.01), Lateral : 0.3(0.01)
Tire
Size
Inflation pressure kg/cm² (psi)
P215/65R16, P235/60R16
2.1±0.07(30+1.0)
Apr 30, 2009 | Hyundai Tucson Cars & Trucks
Phil and Teds Sport, front wheel shudder
you can phone Out n About 01234 344230 email: info@outnabout.com they are the importers for phil n ted or try www.buggypitstop.co.uk they service and repair Phil n Ted
Mar 01, 2009 | Regal Lager Phil & Teds Sport Buggy Single...
Baby Gear Logo
226 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
