I am having paperjams at the fuser area only on color copies/prints. Most frequently from trays 3,4,5. Less frquently from tray 2.Black and white copies /prints no problem. Could it be the transfer belt / timing issues?
    Top Expert:
  • Office Equip... Master
  • 78,254 Answers
Yes I would say you may need the belt is replaced due to stretch and needs to be replaced. You could also have allot of dirt built up from the print drum leaking
Posted on Feb 07, 2012
  • 105 Answers
SOURCE: paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Posted on Mar 28, 2008
checkitright
  • 1362 Answers
SOURCE: Brother MFC 8460 N, all
Make sure the stopper in the paper tray is snug against the paper. sounds like the paper is not properly in place and the tires are making the noise.
Could be it's trying to lift the tray and it can't, determine why; something stuck, out of place,
Posted on Jul 21, 2008
rwandrew
  • 115 Answers
SOURCE: I have a paper jam in the fuser/paper exit area
If you can't get to it, and do not want to further disassemble the unit, it would be best to turn it over to a qualified service person
Posted on Oct 03, 2008
yooperbud
  • 8637 Answers
SOURCE: HP LaserJet 5550DTN jams at transfer unit
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 165 Answers
SOURCE: pagepro 1350 will not feed paper
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
Posted on Jan 27, 2009
WHO DO I CLEAN PRINT HEAD OKI MB451W
The MB451W uses electrostatic toner and does not have print heads. Follow the cleaning instructions beginning on page 172 of your User's Manual. If you don't have it handy, you can download it from the OKI website. (The link is for the English language manual.) http://my.okidata.com/mandown.nsf/196efed9e03ff0d1852576ee00476710/3854f93fb3d0181185257a7f004eddcb/$FILE/MB461_MB471_MB471w_MB491_ES4161%20MFP_ES4191%20MFP_MPS4200mb_Basic_UM_E.pdf.pdf
Note: on page 174, the manual recommends "soft tissue paper" for wiping off the LED array lens. Lens-cleaning paper or cloth for plastic lenses should work and is less likely to leave lint behind.
If you are getting random black blobs on the back of your printout after cleaning the printer as recommended, the fuser is dirty. If the fuser cleaning strip is accessible (a felt strip that wipes off the fuser roller during operation), gently scrape it clean with a knife blade held perpendicular to the strip, then clean the debris out of the printer. (CAUTION: the printer must be off long enough to be cold before working on the fuser!) If you can't get into the fuser, use the following procedure: Get matte-finish paper of the thickest stock your printer will handle. Put several sheets of this paper in the paper tray. At the computer, type a single space on a blank document, with no headers or footers, then print the blank page (trying to print with nothing at all usually doesn't work). This should pick up some of the trash. If you still have problems, open a graphics program and draw a solid black rectangle all the way across the page ("portrait mode") and about 4" high. Place a copy of this rectangle 2" below the first one. Insert a page break, and put a white object (anything white or transparent, with a white boundary) on the second page. Print double-sided. The black rectangles will pick up dirt from the fuser roller and the heat will make it stick to the paper toner. Repeat if necessary, then remove any unused cleaning paper from the tray.
May 12, 2014 | OKI PRINTER,MB451W,120V,BG
Bizhub c552 is printing faded image across part of the page in color and black/white
can u upload a copy of the problem? can the faded part be rubbed off? if so its your fuser that needs replacing - very expensive. if it doesnt then in tray 1 you have a flap at the front of the tray with a laser slit glass cleaner - pull down the bottom cover at the front and put up and down the holes in front of you at the bottom. should have arrows pointing
Oct 04, 2013 | Konica Minolta Office Equipment & Supplies
I have a Richo 2035 black and white copier. Recently the copier has begun to paper jam...and its done frequent every time i clear the jam..it runs for a while maybe 10 copies and jams again. What can i do?
Not surprising - it may need some service. It is 7-8 years old. There are a few areas that could be affecting output. Most likely you need to replace the rollers that pick the paper out of the tray (3/drawer) -especially if the problem occurs with 1 specific tray. Try using another tray to isolate the problem
Jul 10, 2011 | Office Equipment & Supplies
Ghosting
Normally ghosting is caused by a bad fuser.
Put paper in the manual feed tray(tray 1)
Print something. As the paper gets 1/2 way into the printer, open the cover..
Look at the paper. If there is no ghosting, the fuser is bad. If there is ghosting, could be a cartridge drum.
Follow these steps print a Print quality troubleshooting page to identify which print cartridge is causing the issue.
  1. Open Toolbox .
  2. Click the Help folder, and then click the Troubleshooting page.
  3. Click Print , to print the page. The page prints five bands of color, which are divided into four overlapping sections. By examining each section, you can isolate the problem to a particular print cartridge. Figure 4: Print quality troubleshooting page bandsc01417618.gif 1 - Yellow 2 - Cyan 3 - Black 4 - Magenta
May 01, 2011 | HP LaserJet CP1215 Color Printer
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Hp laserjet 2600 ghosting
You are most likely correct. this is called fuser offsetting, to check it out, stop the paper being printed MID CYCLE open the front door just when you think the paper is behind it..., pull the paper off the transfer belt. Is the ghost there? Probably not, and if it isnt, then it is your fuser. I can lead you to a reputable supplier. You can buy QUALITY rebuilt fusers with great warranties at prices well less than new OEM.
Mar 11, 2009 | HP Color LaserJet 2600n Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
18 people viewed this question
k24674
jasbo
jasbo
