Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Low or no fire to points
Late 84 classic had been rebuilt before i bought it. h.e.i. went bad and i reverted to points and condensor. washed the bike and bike ran rough. attributed it to something may have gotten wet. now two days later i am getting barely any spark and even when running there is no noticable change to it when adjusting either points or carb.
  • Anonymous Nov 01, 2008
    Sort of the same problem however didn't change e.f.i. on 1983 shovel but did change carb with no difference in the way it ran. Advanced and ****** timing with no change in the way the bike ran. Please help
  • 91 Answers
Did you change the plug wires to solid core wires hei uses a fiber core wire with almost no resistance and points need around 3-5ohms resistance, the coil needs to be for points also this should make it run right
Posted on Jan 01, 2009
My Midnight venture 2005 just had carbs rebuilt but the bike still back firers, what could cause this problem?
wrong timing, if it did it when you bought it, shame on you, take it to a certified dealer and let them fix it
Jan 22, 2015 | 2005 Yamaha Royal Star Midnight Venture
Harley Davidson - FXSTI Softail standard cranks but will not start
Hi Anonymous, This one is a tuffy since I don't know what year your bike is. If you have an early model you could have a bad run/stop switch, ignition sensor, ignition switch, ignition module. If you have a late model could be crank positon sensor,electronic control module, but on the late stuff you can pull up trouble codes on the odometer and that would at least point you in the right direction. Good luck
Apr 17, 2014 | Harley Davidson FXST - FXSTI Softail...
I got fire to my points on my 4 cylinder 1932 ford but not to my plugs what's wronghat wrong
Could be a bad coil. Check its resistance and compare to specs (find some real old mechanic to tell you what specs to expect, if you have to-lol). Also could be a bad high tension lead from coil to dist. cap-can also be checked for too much resistance.
Do the points open and close when engine is cranked? Are they set right-about 0.015 inches- or two matchbook covers placed together? If coil and high tension cable are good, and points are good and set right, the condensor that goes with the points may be bad-try a known good one-I'm assuming that old car has a condensor to trap the current when points open so no sparks at points occurs.
If everything checks out so far, maybe the distributor rotor is not making good contact to transfer the high voltage current from the coil cable to the spark plug wires.
Mar 18, 2013 | Cars & Trucks
95 softail classic started and was warming up and just died and wont start, will fire with starter fluid but thats it, will not keep running, has appr. 30,000 miles
If the bike will fire with starter fluid but won't run on it's own, I'd say you have a fuel problem. In 1996, Harley introduced a vacuum operated fuel petcock. I see that you say your bike is a '95 model but Harley has always been known for crossing over year models with certain parts. Say you bike was built in late '95 and they ran out of the "old" style petcock. They just switched to the "new" style at that time instead of making more "old" style parts. That's where the term "transition model year" came from. So, check your fuel petcock and the vacuum line running to it. Pull the fuel hose off the petcock and spin the engine. Watch for the fuel flow and determine whether it is sufficient. If not, replace the petcock. Personally, I went to a Pingle manual fuel petcock. Of course, you have to plug the vacuum hose as it's no longer used. But, that was the end of petcock problems on my bike. Just turn your fuel on and off manually, "old school" style.
Good Luck
Sep 13, 2011 | 2000 Harley Davidson FLSTC Heritage...
KLR 600 year 84.miss fire will not start
Exploded views of the whole bike on the above sight. Should help you get it all good. Make sure to set timing at TDC before gettin the head/cams/chain etc ready. Cheers
Mar 27, 2010 | kawasaki KLR 250 Motorcycles
I have recently rebuilt a vintage motorcycle and it will not fire up. The ignition is set properly and a get a good spark when the plug is out. Capacitor and coil seem to be OK. I does seem to flood...
Try using a short burst of starting fluid into the carb. Don't give it gas.The object is to get it to "fire". Don't use this stuff more than once or twice. In the winter I have used it because of hard starting. What carbs are you running.. 930s? In it "trying to fire" Do you get a "bump". What year is this bike? You can also "prime" by hand with "petrol" .. just a small squirt into the carb.. stay off the throttle. The whole idea is to get it to fire and the compression from that may get the carb to work.
Have you rebuilt the carb? What book are you using?
Testing a float is easy.. stick it under water and if you see bubbles it is dust.
Flooding mean the float might not be right, I take it you have one carb.. some guys do switch the heads and manifolds.
If all fails on the old carb you can get a new PWK. The other thing I have done on my Triumphs is get rid of the Zerner Diode and Rectifier and use an electronic Selnium Recitifier. they run about $50. The capcitors (condensors) last about a yr when running points. A good upgrade is to go electronic but points work well.
Here is what they look like;
Mar 21, 2010 | Triumph Tiger ABS Motorcycles
I just bought this bike a month ago. It is an '03 VTX 1800. I went on about an hour and a half ride and during the ride when I got to about 60 mph the engine would sputter and loose power at points. I...
Electrical ... check points. You jmight want to run some carb cleaner through it ... change the plugs. Id look at the points or what ever turns the coil on and off, real close.
Sep 29, 2009 | 2003 Honda VTX
Plugs Fowling 79 shovel
Install a Dyna, or equivalent, electronic ignition.
Jun 07, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
71 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
