Question about Canon DR-9080C Path-Through Scanner
Error message - pixkofax version 1.16.11102-1001 (-4523)
This is the error message i am getting on my scanner
I cannot use my AGFA SNAPSCAN 1236 with Snow Leopard
I had the same problem. Upgraded from G5 PowerPC Tiger OS to iMac Snow Leopard. Have a Snapscan 1236U (ScanWise) and got the same error message ("cannot find the current ColorSync System Profile"). Downloaded trial version of VueScan (www.hamrick.com) , scanner worked, so purchased the VueScan Professional Edition ($79.99) (Standard Version is $39.99). My scanner is now working GREAT!
Jul 27, 2010 | Agfa SnapScan 1236u Flatbed Scanner
MicroTeck ScanMaker 1800 - Error = -1
There is a new version of SW Pro - 7.7.1 which fixes this. You must download the and run the Uninstaller first (from Microtek too). URL: http://support.microtek.com/downloads/drv_specific.phtml?slct_os=20&prod=37&bymdlnme=1
Cheers
Apr 07, 2010 | Microtek ScanMaker i800 Film Scanner
"Problem with installation unit may not work" Error message keeps telling me to turn on scanner or plug it in. Have re-installed the software but same error messages appear.
did u follow the installation instructions for the scanner, sounds like you may have missed a step or done the software installation incorrectly, there are ways around any problem like this, it all depends on what the operating system of your computer, so let me know if you can't get it right what operating system u have, also remember many many types of hardware get sold with software that is defective, so go to the Agfa product support site for the scanner and download the latest version of software
Feb 02, 2010 | Agfa SnapScan E52 Flatbed Scanner
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
When I try to open the Scanner software the following comes up... Error = 4 Could not confirm scanner connection.Please check scanner connection. When I try to open the easyscan Utility I get the following...
Minolta's crummy software is notorious for this. Most people can't get it to work even by removing and reinstalling the driver software. The best solution is to use a third-party driver software called VueScan. You can download a trial version for free to see if it works before you commit to buying it. If this doesn't solve it, you most likely have some sort of hardware problem.
http://www.hamrick.com
Jul 19, 2009 | Minolta Dimage Scan Elite 5400 Film...
Will not do final scan
What version of windows are you using? Which software are you using to do the scan, and what version? It sounds like either the version of scanning software is incompatible with the version of windows, The USB connection (Assuming it is connected via USB) is a older USB connect (1.0 or 1.1) and a update to the firmware is causing a fault in the final scan, or finally the scanner has gone defunk... time to get a new one.
Jun 19, 2009 | Visioneer OneTouch 9000 Flatbed Scanner
Scanner 3450, software 3.75 version
You can download the driver from the following link :
http://driverscollection.com/?H=Astra%203450&By=Umax
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 08, 2009 | Umax Astra 3450 Flatbed Scanner
TWAIN message
The Twain error message sounds like a Windows error... I wonder if the software you are trying to use is for Windows, and not MAC.
Chester
Jan 11, 2008 | Canon CanoScan 9900F Flatbed Scanner
MINOLTA SCANNER DiMAGE SCAN ELITE 5400 II
My 5400 2 scanner worked well with windows XP but will not start with my new computer WINDOWS VISTA.
ERROR message Can not find scanner, check connection
ERROR message 1 unknown error
The scanner was purchased new 1-2006
my installation dick is for Win. XP Version 1.0.1.
Dec 25, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Canon DR-9080C Path-Through Scanner Logo
120 people viewed this question
old marine
old marine
