Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
We have a nosiy fan on a Whirlpool freezer model EVL201NXRQ05 with a solid back,hoe do one get to the fan
2 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Fan Noise coming from back of freezer compartment
Check the door seal to ensure outside air not being pulled in . You could have a defrost problem if frost build up on rear freezer wall .
Posted on Jul 19, 2009
My whirlpool refrigerator freezer (top) is frosting the food up. Food is not frozen solid. The motor or fan keeps clicking on and off. Refrigerator is only 1 1/2 years old.
1) the wires behind panel, inside of freezer may have loose connections,or I ran into a bad compressor with a brand new fridge, that is back of unit, bottom left or right, take off cover to check if connection is good there also.
May 20, 2017 | Whirlpool Refrigerators
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Need to replace evap motor for a whirlpool freezer
9abb6871-4eeb-4e17-b4b8-c4bfdafab542.jpgUnplug the refrigerator and remove the contents of the freezer. Then remove air tower and the inside back panel inside the back of the freezer. Disconnect the evaporator fan and replace with the new fan motor. W10189703 Evaporator Fan Motor I am here if you have questionsm Thanks Sea Breeze
Apr 20, 2013 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
I have a whirlpool 6wmv43 model the fan in the fridge part is not working..how do I get the fan out..Cheers
The fan is behind the back panel in the freezer to access it you need to remove the screws that hold the back panel on. let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool ET8RHMXKQ Top Freezer...
Freezer comes on fan starts after a few seconds goes off freezer unit freezes solid fan doesnt come on again fan is ok
Good day,
When the thermostat is turned on, the fan and compressor should come on and start at the same time. If the compressor continues to run and the fan doesn't, then the fan motor or the wiring to it are suspect.
Quote (The fan motor is o.k ). I doen't know how you tested it, but it still remains suspect, since the thermostat sends power to both of them at the same time.
Nov 03, 2009 | Whirlpool Freezers
My whirlpool refrigerator (Model ET18DK) does not cool
Most likely one of two conditions are the root of the problem. Either the fan in the freezer is stalled or the defrost system has failed. The fan in the freezer should run any time the comressor is running; if it's not, there's your problem. If you can hear the fan, check for frost or snow developing across the back panel in the freezer. Local repair service could probably supply replacement parts quickly for defrost failures (most likely a bad terminator if defrost system isn't working).
Apr 25, 2009 | Refrigerators
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
Jan 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Upper freezer is squeling
The most likely cause of the squealing is the eveporator fan motor. It may continue for quit a while before it finally quits. When it stops completely the evaporator coil will freeze solid and there will be no air blowing from vents to refrigerator.
Dec 20, 2008 | Whirlpool Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
63 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
