Question about JVC TM-2703SU 27" TV
Jvc av36d202 d-series
I turn on set by manual on button on tv as remote wont work anymore and the set turns on and the volume automatically turns up max volume and if you turn it down it goes back up again and channel wont change from channel 02 menu displays but wontwork either . any help would be appreciated thanks.
  • Mark Jones
    Mark Jones Dec 06, 2012
    your controller board has got damp or wet .it is making connections as build up is making the need to take it out and get a magnifying glass to see what has build up .the controller is right behind the buttons at bottom front of tv. i fixed two tv,s already .it takes delic=ate work but my tv is fine now
  • 3130 Answers
SOURCE: Video will not turn off; "I2C-BUS STOP MODE" error at power up
Nope a very easy problem .. What it is is the relay is stuck on or closed so when you plug in the set the power comes up But the micro hasent told the rest of the set to work yet. So when you hit the power button. its just like you hit the power and it activated the relay and the rest of the set. Now in some rare occasions the driver transistor for the relay was shorted But most of the time its the contacts that weild shut, but you cant just clean them as it will work for a while, but in a month or so you will be in the smame boat. But if you not a tech this repair shouldnt cost you to much because if your not an experienced tech you can not only cause harn to the set but also you yourself BE CAREFULL and take the set to a pro!!!! Good Luck
Posted on Jul 27, 2006
  • 1694 Answers
SOURCE: Need manual control board (power,volume, channel and menu push buttons)
Manual push buttons part number should be CM35776-B01-SA.
Give me a few hours--I'll get the remote part number....T
Posted on Oct 31, 2007
  • 50 Answers
SOURCE: Get get any responce on my JVC AV27530 27" TV
,,always unplug the set from AC,leave off a few minutes,,then re-plug back in,,that resets the micro--also,it could be the volume up button stuck-that would kill the other keys from working--you could try with a tooth pick to pull VOL UP back----THIS IS DANGEROUS --SHOCK HAZZARD!!! if someone is technically incline,with the back of the tv off,,turn set on and unplug the keyboard plug from the main circuit board while the set is playing--then use the remote and see if the fuctions returned-THIS IS DANGEROUS-SHOCK HAZARD---I REPEAT -DANGEROUS!!!! PLEASE BE CARFULL,if that cures the problem-you have a bad keyboard-you can just leave it unplugged and use the remote----JUST BE CARFULLLLLLL
Posted on Mar 22, 2008
  • 1689 Answers
SOURCE: TV powers on and then cannot change channel or change volume???
The fault may be the control panel, or it may be in the uPC itself.
Most of the time, it is some of the switches on the control panel.
The most common cause of this type of failure is that many times when people clean the TV set, they spray cleaner directly on the screen or the set. The liquid runs down in to the set and causes damage. Sometimes the damage can be very expensive!
If the fault is just the control panel board, this can be easily replaced. You can order one from the manufacture's parts department or from one of their parts distributors.
You will need the service manual, a scope, and a DVM to troubleshoot the problem if it is more involved than just changing the panel. The only way to know is to try the panel unless you have a way to test it.
Jerry G.
Posted on Jun 30, 2008
SOURCE: JVC TV LT-32G80BU can't navigate in menu + all channels messed up
TV seems to reset it's settings for some reason (it happened to me with similar TV - LT-32A80SU). I have found the way to solve this situation - service menu.
Press button "i" and "mute" on remote at the same time - service menu should appear. Now press 8 and there should be menu that allows to change few advanced features. Pressing down and up arrows allows to navigate, pressing right and left arrows changes values. You have to change "dual HDMI" to YES (this will enable second HDMI port) and change "remocon" to other option available (this will change how the remote behaves). Save settings by pressing OK button. Now you can leave service menu by pressing "i" button twice. You should now be able to use your TV like before.
Remember - these are instructions for my TV and they worked for me but playing with service menu can be dangerous so you're doing it at your own risk. Ask JVS support if you're not sure what to do.
Posted on May 12, 2011
Sylvania tv without remote video channel
Volume up button (turns it on) so does channel up,
Input select is under the front panel of the Screen, and channels wont work anyway cause analogue signals is no longer broadcasting anymore so you wont receive a station without a set top box.
Jan 14, 2014 | Televison & Video
Wont change input
sounds like the volume up button is stuck on the tv , try fiddeling with it on and off , because it is locked down the other controls will not function
Feb 07, 2012 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
With the JVC D-series TV do you need a Remote Control to turn on the input screen?
No. Almost all TVs can be turned on manually.
However, those of us who are TRUE couch potatoes would NEVER rise from our seated positions to do ANYTHING manually when there are remotes that allow one to do the same thing from a comfortable distance!!!
If you look on the right side or across the bottom front of the unit, you will see the various buttons for power-on, volume, channel selections, etc....
Jan 01, 2010 | JVC AV-32D305 32" TV
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
Goldstar 2,9
Hitachi 8
Magnavox 4
NEC 2,9
Pioneer 6
Philips 4
Sanyo 0
Sharp 3,5
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
JVC Interiart 27" TV
Hey there Andy l rekon ya busted yer remote so best git on down to the store an git yerself one a them universal remotes for xmas.
Nov 17, 2017 | JVC AV-27D302 27" TV
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Oct 30, 2007 | JVC AV-32950 TV
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum ( and it fixed my remote problem:
"'s possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
Lost tv code
Here are some of the codes2.gif still looking for manual
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Mitsubishi TV4.gif 0093, 0150, 0178, 0019
JVC2.gif VCR 0067, 0041, 0008
JVC DVD1.gif 0558, 0623
samsung1.gif codes is 1004,1005,1006,1012,1013,1015,1017,1019
Motorola2.gif Cable2.gif Box: 5000, 5003, 5046, 5047, 5052
Comment by Gigatech, posted on Dec 10, 2007 Here is some helpful information4.gif I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device4.gif button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Jan 03, 2007 | Jensen 143307 Remote Control
JVC TM-2703SU 27" TV Logo
141 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
