Question about Konica Minolta Minolta FAX3900 Digital Copier, Copier/Fax Machine 16 ppm printing and up to 600 dpi resolution, rec... Printer
Comm error 004f
Receive the comm error 004F error after sending a fax
2 Suggested Answers
SOURCE: Not receiving faxes
R18 means that your memory is full. Very strange. Go into the user box, file document, system user box, memory rx to delete all of the old faxes. This worked for me.
Posted on Sep 24, 2009
Code c004f
I get error code C-004F when i start my Bizhub C350. How can I solve this Problem?
Aug 17, 2013 | Office Equipment & Supplies
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
DI 450 KONICA MINOLTA ERROR CODE C0070 AND C0F24
if it;s not the bottle home position it may be you toner happer motor...clean it and try to take the bottle our and close the door and than put bottle back in
hope that help
Feb 25, 2009 | Konica Minolta DiALTA Di200 Copier
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
566 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
