As stated, the forumla solution in is
= (Due Date - Create Date) x 24
However, the key is that the result cell (where the formula is) should be formatted using the 'general' format, not date/time. So, I think in this example, the result should be 730.65 hours
Hello ycool11,
If your asking what i think you are the formula would be
=(a2-a1)*24
That assumes a2 is that last date entered and a1 is the initial starting date. if you would like a more intense formula let me know and i'm sure i can help.
I am writing a user spreadsheet that requires a couple of drop down choices to prompt automatic cell...
(More)
I am writing a user spreadsheet that requires a couple of drop down choices to prompt automatic cell fills. I know how to create drop down lists. I cannot figure out how to get the drop down selected to prompt entry of the appropriate value into the appropriate cell or how to get the proper field to be presented when the appropriate choice is given. One of the dorp downs is a five choice drop down and the other is two. They both have cells or ranges that are appropriated by their selection. The five choice drop down has five fields to choose from to feed the appropriate cell the two choice drop down has two separate fields of data to present or input to.
using an excel sheet, assume that sum of some cells is 100.77 and i want to use this sum in other...
(More)
using an excel sheet, assume that sum of some cells is 100.77 and i want to use this sum in other cells but 100 in a cell and 0.77 in another cell, so what is the equation or what can i do to do it ??
