Question about Husqvarna Sewing Machines
Huskylock viking serger machine is very noisy / squealling; oiled / cleaned machine, changed needles... It gets quieter if I sew fast.
  • Anonymous Mar 14, 2014
    i did clean it oil because was very noisy and now it is sewing backword without presing the back button of course
  • Husqvarna Master
  • 7,365 Answers
Some machine make more noise than others, but to be on the safe side I suggest having the machine check to see if there is something else wrong, it could be something is loose or worn in the machine.
Posted on Feb 08, 2012
    Scholar:
  • Husqvarna Expert
  • 104 Answers
It's possible the needle is hitting the rotating "hook" mechanism in the arm. As the needle goes down, the hook mechanism is timed to rotate into position to engage the thread of the needle. This hook is on a thin arm that can be bent by the needle (in the case of a jam or misinstalled needle). If the needle hits the hook, it makes noise. If there's excessive clearance between the needle and hook, it skips threads. The machine has to be taken apart to get at the hook. If you're not mechanically minded, leave it to a repair person familiar with sergers.
Posted on Jan 21, 2013
  • 192 Answers
SOURCE: I would like to know where I could find a serving & repair shop
Use the dealer locator:
http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Posted on Sep 29, 2008
  • 11 Answers
SOURCE: user guide Overlocker/serger Husquvarna Viking Huskylock 905
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 24, 2009
Zenqi
  • 208 Answers
SOURCE: Need Huskylock 535D all purpose need plate
The parts catalogs show this part as obsolete.
Try Googling the top Husqvarna Viking dealers to find one with spare parts from junker machines. Most dealers have a good supply of used plates.
Posted on Jul 25, 2009
Zenqi
  • 208 Answers
SOURCE: I need a threading diagram for a Viking Huskylock 560ED serger
Call Husqvarna Viking at 440-808-6550 and they will email you a PDF of the manual.
Posted on Oct 01, 2009
  • 371 Answers
SOURCE: I need to know how to thread my Viking Husqvarna
You have a great machine. These are hard to thread but once you have mastered it, you'll have many years of great use. The owner's manual has instructions, as well as the inside door of the machine (the door that folds down on the front bottom part of the machine. However, you might want to follow-up with your local authorized Husqvarna Viking dealer. Most are eager to help you even if you didn't purchase the machine from them. Some even have classes on using the serger. You might try several stores in the area. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
One fundamental tip is to follow the color coding, start with green, then blue/navy, then red, and finally yellow. The sequence is work inside to outside with threading (green - blue - red - yellow). Do not try different order--especially with green and blue -- since the threads build on each other. I have switched yellow and red with no impact but green then blue is always the proper order.
Good luck.
Posted on Feb 11, 2010
Viking Huskylock 560 ED threading diagram
Viking 560 ED Huskylock Handbook
Threading Serger this may be helpful even if it is not the same model. The sequence of threading loopers is VERY important. If you thread them out of order, be prepared to be frustrated beyond belief!!! Something else (I don't think she mentioned) is to ALWAYS RAISE the presser foot when threading your machine. This is true for sergers AND sewing machines!
How to thread Serger
Nov 17, 2016 | Sewing Machines
936 Huskylock needle bar does not move up and down.
First, make sure the machine is engaged to sew. some machines,
have a knob inside the flywheel on the left side that disconnect the sewing mechanism to wind a bobbin without the needle bar moving.
Cheers,
Embroidery Services
San Diego, CA
Jun 15, 2016 | Sewing Machines
How to fix a broken Needle clamp on viking 936
I don't know of a way to repair the needle clamp. It will more than likely have to be replaced. The local authorized husqvarna viking dealer should be able to service the machine. You can find the nearest dealer from husqvarna viking website - http://www.husqvarnaviking.com/us
Apr 24, 2014 | Husqvarna Huskylock Computerized 936
Needle seems to be hitting the plate and sounds
sounds like the sewing head is out of line. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 10, 2010 | Husqvarna Huskylock Computerized 910
Hi, I have a huskylock 905 NOT computerized and it's making a "clunking" noise while sewing and then the "D" thread breaks. I've re-threaded many times, changed thread, changed needles, adjusted tention...
Sounds like the D needle is hitting something in the loopers and an adjustment needs to be made. The adjustments are ever so slightly. It could be that the needle bar is twisted causing the D needle to hit. It could be the looper is not within the specs for proper operation, etc. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 18, 2009 | Husqvarna Huskylock Computerized 905
Need power cord forHuskylock 435 serger and
That serger was made for Viking by the Brother company. Just about any sewing machine repair shop should be able to get you a cord and pedal. Call Viking at: 1-800-474-6437 to see if you can get a photo copy of the manual.
Oct 28, 2009 | Husqvarna Viking 1
Sep 25, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
142 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
