Question about Sewing Machines
Machine very noisy / squealling, oiled / cleaned it, changed needles,
  • Sewing Machines Master
  • 7,365 Answers
You might consider having the machine serviced
Posted on Feb 08, 2012
3 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: upper thread keeps breaking
the tension is too tight give it a little slack on the top.good luck.
Posted on Feb 28, 2010
  • 48 Answers
SOURCE: upper tension too tight. Have
You need to check to see if your bobbin tensioner has broke. Look at your schematic to determine if everything is still where it's supposed to be. Good Luck.
Posted on Apr 20, 2011
Machine appears noisy after breaking needle.does it need oiling.
probably but I suggest that you take it in and have the needle/ hook timing checked as it may have altered from the needle breaking ans is hitting on the bobbin carrier
Nov 28, 2015 | Sewing Machines
Won't sew every time I turn the wheel needle won't go the way down gets stuck noisy
If your machine is mechanical (NOT computerized) it probably needs cleaning and oiling. Consult your owner's manual and use ONLY recently-purchased good quality sewing machine oil.
Oct 11, 2015 | Singer Sewing Machines
I want to clean my Singer 6510 machine, It always needs me to pull down on the wheel to get it started, kinda hard to do when you're using both hands to hold the material in place! However, in the...
Yes this is lint that should be vacuumed out after every 8 hours of sewing. Sometimes we see this lint build up to the point the machine will break gears. Often the lint between the feed dogs and needle plate will keep the fabric from feeding.
You can purchase sewing machine oil at any sewing machine store. It is non staining and 10 weight. You can also use Triflow as another option. Triflow has a generic Teflon in it that leaves a slippery residue for a long time.
If your machine is hard to turn with the hand wheel it may be a bearing or gear issue.
You may enjoy a new machine with the control that allows you to put the needle up or down with the touch of the foot control. After using one of these you will never want to sew on a machine that does not have the pivot on the needle function.
Oct 12, 2013 | Sewing Machines
Brother 1034d serger. Seems unusually noisy (mechanically) in needle/cutter area. Not motor or belt as noise is metal parts clacking even after new needles, cleaning, oiling. Is this sound normal for...
in response to all serger, no, after my babylock serger is cleaned and serviced it runs quietly.
as for the brother, it's possible thats normal, try contacting a repair shop in your area and tell them about the serger and see what they say.
it's possible that the serger may need some type of adjustment
or a part may have broken .
Sep 06, 2013 | Baby Lock Eclipse Serger
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Huskylock viking serger machine is very noisy / squealling; oiled / cleaned machine, changed needles... It gets quieter if I sew fast.
some machine make more noise than others, but to be on the safe side I suggest having the machine check to see if there is something else wrong, it could be something is loose or worn in the machine.
Feb 07, 2012 | Husqvarna Sewing Machines
Is a little bit noisy while sewing
your description is brief so not sure if this is an old machine, new machine, never been serviced, or what brand and model.
But all machines need to be cleaned (bobbin hook area) with a little brush to remove lint and built up. And oiling the designated points as per your sewing machine manual.
And the needle should be changed for each new project, a needle is good for 4-6 sewing hours, after that it will blunten. If you stitch slowly and can hear squeaking or popping noices, needle is blunt.
For general maintenance tips if you don't have a manual yet, try www.sewing.about.com, its got lots of info.
Mar 07, 2011 | Sewing Machines
STITCHES DEEP TO BOBBIN SIDE HAVE CHANGED
You do need an oiling and cleaning. Also, try adjusting on the bobbin cover by turning th little screw with a small screwdriver. Keep adjusting and testing until you get the loops just as you want them...
Aug 05, 2009 | Sewing Machines
Singer 7442 is Loud!
Check to see that lint or oil has not collected on the hook or needle bar. Always use a good quality sewing machine oil. A damaged needle can also be the cause of a noisy machine - insert a new needle.
Nov 21, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
