Question about Shop Vac Shop-Vac& Mini Hang Up Wet/Dry Vac Vacuum
Manual Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...Model 2015A
MakikiChris
  • 84 Answers
SOURCE: emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Posted on Aug 02, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Posted on Jul 16, 2008
  • 744 Answers
SOURCE: Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
Posted on May 16, 2009
kitt98
  • 26 Answers
SOURCE: How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Posted on Nov 05, 2009
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
How to get the filter out of the vac to replace
Push the tabs on each side of the canister at the same time and pull down on the bottom(black part). You will see a light blue filter paper that is held on with a black plastic ring that is pushed all the way towards the motor. Pull that ring off and the blue filter paper comes off. You can buy new ones at Wal Mart, but it's only necessary after it starts getting ragged. Just take it outside and shake it real good and put back on the same way it was on before.
Jun 13, 2015 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
How do I empty the mini shop vac?
Pull out on the clips on each side while pushing on the red part in the center of the clips. Pull black bottom away from the red top while pulling out on the clips.
Dec 11, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Shop vac stopped working
Motors have a thermal safety fuse in the field winding. If it overheats, it will blow and either can be replaced or the whole field winding will have to be replaced. It is wired and is not considered to be a user servicable item.
Apr 22, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Can't get hose back on model 2E200
Fit rounded side into the top red part first. The flat side is toward the bottom black part. Then push the bottom on until it snaps in place on each side.
Feb 21, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Need manual
Check the manufacturer's web site, or if you recall where you purchased it, they maybe can get a
hold of one for you.
Sep 23, 2013 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
I have an old shop vac floormaster wet & dry vac, 8 gal., model 700c. I need the users manual to find out how to use it as a wet vac.
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Jul 04, 2011 | Vacuums
Do I take off the dry bag and the fome cover when picking up moisture ???
dont know what model you have, but, as a rule, the dry bag is for dry vacuuming and the foam is for wet vacuuming.
Feb 12, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop Vac Shop-Vac& Mini Hang Up Wet/Dry Vac Vacuum Logo
519 people viewed this question
Top Shop Vac Vacuums Experts
Jim Parker
Jim Parker
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
