Question about GE Profile 36" Electric Induction Cooktop - Black
Ge Induction cook top right rear burner,timer and control lock do not work
All Other 4 burners work fine. The timer ,control lock and right rear burner do not respond to touch.. I have tried turning off the breaker but did not help
  • purexkite
    purexkite Feb 09, 2012
    I guess this not a common problem? Do you guys think there may be a loose connection? any Ideas Really love this cook top would love to have everything working as it should again
  • purexkite
    purexkite Feb 10, 2012
    I figured out how to fix this myself.. Underneath the glass surface is a control board that contains the button controls and for some reason the Top protion (top 3 control switches) of this control board was not making good contact with the glass. I stretched the little springs that help this board make contact with the glass and everything works now... Thanks
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
Controlfrk
  • 304 Answers
SOURCE: Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Posted on Aug 31, 2009
milten1
  • 1304 Answers
SOURCE: The igniter on the right front burner of my GE Gas Cooktop
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Posted on Oct 17, 2009
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
  • 457 Answers
SOURCE: I have a GE 30 inch electric cook top. 2 days ago
sounds like the heater coil is defective or switch is bad. service tech is needed for this. components has to be checkjed properly.
Posted on Feb 24, 2010
Testimonial: "Thanks, This tip was very helpful."
Gaggenau 200 Series?
If it is similar to the VE260 model, this induction type of cook top is very old. 22 - 23 years if it came with the home when it was built.
I can only offer basic suggestions of which you already probably know.
These induction type cook tops rely on the pan or skillet to be magnetic like stainless steel. If the bottom of the pan has any buildup of residue, this will dramatically reduce the efficiency of the unit.
If the pans are immaculate, then the electronic elements that produce the magnetic induction to heat the coils must be weak. As old as the unit is, it is probably not feasible to have 3 of the elements repaired....
A new top can be purchased much cheaper. Consult Consumers Reports for unbiased product reviews for your best reviews. As a final suggestion, find someone who is qualified to use an electrical multimeter to read the current on both sides of the power receptacle to ensure that your voltage is 230V. A loose connection on the receptacle can cause the elements to have the same result.
Although I can imagine you have already done everything above, I just wanted to send you what I can offer.
Jan 02, 2014 | Gaggenau Cooktops
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
Large section of dual burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
GE Profile 36" Electric Induction Cooktop - Black Logo
85 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
