Question about Campbell Hausfeld Air Tools & Compressors
What oil type for my Sumec 87cc engine on a CH gn1200
Hey I need to know the oil type for my CH gn1200 generator, it has a Sumec 87cc engine. there was a link to the manual on this website but it is now invalid
SOURCE: oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
Posted on Sep 01, 2008
CarlGehrke
  • 169 Answers
SOURCE: need oil type for generator & motor for 5000 power mate
Unless you're in very cold locations use SAE 5W30 regular motor oil.
Posted on Dec 03, 2008
CarlGehrke
  • 169 Answers
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Posted on Dec 15, 2008
  • 22 Answers
SOURCE: oil change
hi,the engine uses sae 30 oil,takes about 1 litre of oil,you can get this from most garages or mower centres,hope this helps
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: Missing Manual
Here is a link for the manual....Sorry for the quality, it's printed on glossy paper, and difficult to scan properly.
http://rapidshare.com/files/285883408/GT-1200C_Manual.pdf.html
Click on Free User, wait the few seconds, and then click on the download button.
Good luck,
fields
Posted on Sep 28, 2009
Testimonial: "Thank you very much for taking the time to do this! It was exactly what I needed."
Hello i need to find a capacitor for my sumec diesel generator (ccbb61 30uf 300vac) cant find one anywhere please help
Capacitors are normally in the end of the alternator, remove the end cover. Most generators it is there
Sep 11, 2011 | Yanmar Diesel 5500 Watt Pramac Generator
I have a homelite hgca11400 generator with a sumec 87 cc gas engine model no.bj0307148.i lost spark to the plug and the unit dosent`have the low oil shutdown.from what i can tell the primrary side of the...
It sounds to me like you have your problem diagnosed. To find the nearest service center for homelite to you go to homelite.com./service and then go to service locator. I could not do this as I don't have your location. Good luck and thank you.
Feb 21, 2011 | Garden
I would like to know what type and how much oil do I use in my powermate generator with the Subaru 10hp engine. thanks you
Your small engines require ordinary 10W30 motor oil.
Don't turn machine on its side or upside down to drain oil, or oil will run into carburetor.
Use a plastic hose to remove old oil
Oct 22, 2010 | Coleman Powermate Premium Plus 6250W...
NEED A BRASS PLUG THAT GOES IN THE BOTTOM OF MY CARBURETOR ON A 12 HP SUMEC ENGINE THATS FOR A POWERMATE GENERATOR.
check with your local automotive supply the do carry small engine carb kits.They may or may not have your kit but can order it or tell you where to find it.
Dec 21, 2009 | Coleman Powermate Powermate 5000W...
Missing Manual
Good luck,
fields
Aug 23, 2009 | Eastern Tools And Equipment 1200 Watt...
Valve spring broke
Not sure but I think someone told me it is a knock off of the Honda? If so maybe try comparing? Ck size, Spring tension & etc?
I know not much help but that's where I'd start. Been told by a local small eng shop there aren't internal parts available for the Sumec engines.
Mike
Dec 09, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Screeching noise from eng? dry bearing? Brass(?) dust in oil?
Hi
I think there is an engine problem.Disassembly entire engine and check all the parts inside(the cilinder, the crankshaft,the piston,the conecting rod,the piston rings,the camshaft(pay attention to the timing points at the gears),the oil pump,the gaskets and so on.
best regards savumihai71
Nov 25, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Air Tools & Compressors Logo
60 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
