Question about HP LaserJet 4600dn Color Printer
Density sensor out of range
Hp 4600 printer with Density sensor out of range message. Is this a part to replace or something I can clean.
  • danhole Oct 23, 2008
    Thank you for the fix. It did not correct the problem. I have now discovered the printer works fine when color is included in the document being printed. If you print with only black text, the black color fades on the right hand side of the page. If you go into the document and highlight one letter, anywhere in the document, the page will print perfect. I am completely baffled.
  • danhole Oct 24, 2008
    The problem: A page with all black text completely fades on the right side of the page. If you take the same document and highlight any 1 letter with any color then the page prints beautifully. attached is a picture of the printout. changed driver and did not help.
    Problem Solver:
  • 9 Answers
The density sensor is located in what is called the Colour Registration Detection Assy. When you open the front door where the ETB belt is, the assembly sits were the door closes at the top on the printer side.
It can get toner on it, so check it and give it a clean. But do not touch it with your fingers.
Posted on Oct 22, 2008
  • jason Feldman Oct 23, 2008
    it sounds Like you have a driver corruption. I would go to Hp's site and download the latest drivers and reinstall the printer on your system using the new drivers. i recommend not using the PCL6 drivers
Where is the density sensor on hp cm1312 colour laserjet?
thank you for your advise. we are having this problem, light black printer, colours are not good. we thought of the laser scanner, but thats above...as opposed to looking down, where toner can fall during print.
Dec 29, 2011 | HP LaserJet CM1312 All-In-One Printer
Our Trusty steed HP 8500 has just started to print a thin twin line and other spurious marks on the top side of prints. Today i replaced the drum / fuser / other bits but no difference any ideas?
I have looked at the manual but there are so many possibilites! You can download the manual here and go to page 148 (PRINTING QUALITY PROBLEMS).
Initially I would follow the directions for clearing drum related errors:
Dark or white lines or streaks in all colors, including black.
Print the configuration page five times. The defect should clear
with continued printing. If the defect does not clear, turn the
printer off and on to reset the printer’s density calibration. If the
problem persists, replace the imaging drum. For more
information on replacing the imaging drum, see the installation
guide included with the drum kit.
Then clean the density sensor.
To clean the density sensor
Open the upper right door.
2 Use the brush located next to the
sensor to remove all toner particles
from the sensor.
Note
You can also use a hand wipe to clean the
density sensor. To prevent scratches on
the sensor, do not use any paper products,
such as tissue or paper towels, to clean the
sensor.
3 Close the upper right door.
It could possibly be a problem with the transfer drum.
I am sorry this is not of much help!
Nov 13, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
Aug 12, 2009 | HP LaserJet 4600 Printer
Hp G85xi ink jet printer. Keep getting the
Possible your printer is equiped with by optical sensor of the determination to density of the paper. If he was littered by dust, that you it is necessary to clean his(its) compressed by air.
Mar 06, 2009 | HP G85xi All-Color InkJet Printer
How to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
2 Use the brush located next to the sensor to remove all toner
particles from the sensor.
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
How to clean Density Sensor of Hp 3500 ?
Thank you for this info. I used your advice to fix my HP printer and it worked. By the way, great link to HP support parges on the www.partshere.com site. I was able to fix my printer and by the way purchased more printer parts and fusers. Thank you again!
Feb 27, 2008 | HP Color LaserJet 3500 Printer
CLEAN THE DENSITY SENSORS POINTING AT THE TOP OF THE TRANSFER BELT. A COLD RESET CAN HELP TOO
Jan 20, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet 4600dn Color Printer Logo
2,057 people viewed this question
Seeker5211
Seeker5211
