Question about Dometic RM2852 Refrigerator
RM2825 not cooling whats the problem
Have check fuses & replaced heater, still not working, no signs of gas leaks.
Maybe its your fan or thoes heater in the freezer not defrosting it. if it has coils on the back see if they ware they should be. and if they are underneath cleam them. but see if it builed up with ice in the freezer by removing the pannel in the freezer. hope this help
Posted on Feb 07, 2012
I have a 03 vw jetta the gas gauge quit right after the heater core blowed is there a fuse or relay for gas gauge everything else works
  • Improper calibration
  • Bad Fuse
  • Problem with the cluster
  • Bad sending unit For fuse location check book or call a auto parts store! God-Bless!
Aug 08, 2016 | Cars & Trucks
5 amp fuse keeps blowing
Hi Jeff,
The fuse is to protect the blower, you and other equipment. It is a warning that something is not working correctly.
If you have a multimeter, use it to see if you have a short circuit or a partial short circuit by using the ohm measurement.
Physically check the wires and and wire connections in the unit to see if there is any sign of shorting out - usually looks like a black smudge.
Do not replace the fuse with a higher rating fuse.
If you can find some short circuit, thoroughly clean the area, or replace the faulty wire, or both.
If you cannot find a fault easily, you may have to get the unit seviced.
Jan 30, 2014 | Air Tools & Compressors
2007 Nissan Altima air conditioner & heater takes a long time to come on
Your Air Conditioner might be low on refrigerant. If the AC doesn't cool down and had signs where it took a while to start cooling, you likely have a slow leak. It could be that an O ring wore out and started leaking, or a hose developed a leak. Rubber components tend to be the first parts that wear out over a period of time. A shop can confirm if your 134A refrigerant leaked out of the system.
Jan 05, 2013 | 2007 Nissan Altima 2.5
I have a Reliance 606 natural gas water heater. It is 8 years old. The pilot light went out on it and I replaced it. I lit the heater and waited 30 minutes to check the water temperature. The bottom of the...
1) Bad gas control thermostat, or thermostat has come out of calibration, or water leak running hot water out of tank.
Turn up temperature.
Replace gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Clean air intake, put ear against pipes and listen for water leak, check that flame is clear blue and that combustion gasses are flowing up the vent pipe and not blocked.
3) Call service technician.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 31, 2012 | Reliance Natural Gas Water Heater Control
What should I do about a small leak on the side of my water heater?
What is the warranty on this tank?
Warranties covered failed tank.
Does the tank wall have a leak?
If the tank is leaking on top around inlet pipes, or leak is coming out of weld around TP valve, then water heater must be replaced.
Copy following link for troubleshooting and method for prolonging life of water heater by turning off heater except to make batches of hot water.
http://waterheatertimer.org/Leaking-water-heater.html
You can buy water heater at local box store. $350 for gas and $230 for electric, then get store coupon or offer 10% less than sticker price.
Electric water heater is simple to replace.
Gas water heater takes more steps, but how-to step-by-step appears on following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 15, 2012 | Water Heaters
MY 1991 JEEP WRANGLER CARS HEATER DOESNT WORK
If the blower works check for coolant in the cooling system. Test operation of thermostat. Check heater control valve for proper operation if equipped. Pressure test cooling system to ensure system holds pressure (this will help you identify a leak, if any. If car does not over heat and cooling system is in good working order, then the heater core is clogged.
If the blower does not work Check fuse, relay, wiring for short to ground, apply direct battery voltage to blower motor. If blower motor turns on and fuse/relay and wiring are ok replace the switch.
Dec 14, 2010 | 1991 Jeep Wrangler
My 1997 Grand Am is leaking antifreeze. It overheats and smells like burning antifreeze. We had a new water pump put on it and a new heater core put on it 4 days ago. Neither of those solved the problem....
it maybe a hose not installed correctly, if it is a v-6 check the intake gaskets for signs of leaking, when you over heat the engine, automatically replace the thermostat, the cooling fans may have a hand in the overheating issue, they may not be turning on due fan motor failure, check cooling fan fuses, very rarely does the coolant temp sensor give out and if it has, that would also be the reason the cooling fans are not coming on, a cracked radiator is also common on gm or any other radiator with plastic tanks. good luck
Oct 21, 2010 | 1997 Pontiac Grand Am
My 2002 Dodge Stratus has been over heating off and on for over a year and we have replaced the thermostat twice and changed the water pump and it still overheats am I missing something? I just had the...
make sure thermostat switch working properly, the thermostate sensor sense the temperature and kick on the cooling fans on and off, also make sure both fans are working properly. assuming every thing is working properly, check the dip stick to make sure there is no water mix in the oil, another sign of leaking head gasket will also will cause the engine run a bit hotter than normal.
Nov 12, 2009 | 2002 Dodge Stratus
I have Honeywell thermostat for gas heater. change new bateries..heat is on up to 80F. Underneath 80F show the picture of "gas" sign..and the heater did not turn on.. What can I do? what's wrong? Please...
Check to see if the gas is on.
Check to see if the pilot is on.
You could have thermocoupler problems if the pilot dosn't stay on, or the safety thermostat within the body of the heater may have tripped.
Jun 12, 2009 | Honeywell Electronic Programmable...
Dometic RM2852 Refrigerator Logo
77 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
