Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Green bulb or tube
When i turn on my tv it works fine fur a min. then seems like i get a power surge to the green bulb and then the tv turns off i had to replace the ic chip already
  • cduris1 Oct 22, 2008
    when i turn on my tv it works fine fur a min. then seems like i get a power surge to the green bulb and then the tv turns off i had to replace the ic chip already
  • outdoorsolut Dec 15, 2008
    mine is the blue bulb. When I turn on my TV it works for maybe 2-3 seconds then 2-3 blue lines appear and then then screen flashes blue and goes into standby. After this happens I just turn the TV back on and it happens again. After 3-4 tries everything works just fine, perfect picture.
Our tv colour has gone all funny do you think that it could it could be the tube that is going. It seems to have green in it as all the faces are green.
It is a Sansui
Posted on Feb 16, 2009
  • 10,594 Answers
Let me know the symptom in detail.
Green bulb (CRT) gives high bright light and tv goes to standby? Do you see few horizontal (retrace) lines while this happens? If yes, you need to replace Green bulb (CRT) of your tv.
Please mention exact model number of tv to guide you further.
and what IC chip you replaced in tv?
Posted on Oct 22, 2008
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
Philips projection - no picture - 51PW9303
there is a lamp to generate sound bad because this is a short-circuit it is recommended that a technical review
Aug 20, 2009 | Televison & Video
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have had a panasonic DLP PT-60DL54 for about 3 1/2 years and up til now its worked fine. The first time I seen a problem the tv shut off after about 5 mins and a fast clicking sound was coming from the...
This is an old posting, but will reply anyways.
I am not sure if this is the same problem that I had , but sounds similar.
I found that there were power surges, or lack of power. I could see my power bar blinking at the time this happened.
So after trying everything under the sun, I plugged it into another outlet with the power bar, and have never had a problem since. It seemed that for some reason I had surges in that line, and have no idea why.
Not sure if this is what is happening to you, but maybe might be of some help to someone else.
Thanks.
Bob.
Nov 21, 2008 | Panasonic PT-60DL54 60" Rear Projection...
Tv turns off then on
It's time for a new lamp. What you are seeing is the result of a weak or old lamp and the TV sensing that it is drawing too much power and turning it off. I've seen this many times; a new lamp will cure. Be sure to buy an original Sony lamp as the aftermarket replacements are known to have problems. Please be sure to rate this solution. Thanks!
Nov 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
Tv was working fine...then shut itself off.
there is no reset button on any tvs that stop in 1980s when they no longer used tubes in chassis,s now the only tube is your picture tube. you probly have a shorted hori out put transistor.
Nov 21, 2006 | RCA F27242GY 27" TV
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
