Question about HP Office Equipment & Supplies
Error code 50.2 hp laserjet4015n possible courses
Cant even initialise
    Top Expert:
  • HP Master
  • 76,070 Answers
Hello
If you go to this Site you will find answers to this error code cause and repair.
Posted on Feb 07, 2012
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
Why code keeps popping up and I cant play games anymore on my laptop
I'm afraid something went wrong on your hard disk. Try a reinstall or a recover from little while ago. Not telling us what OS you are using I can't go in for more details. Sorry. Next time please give as many details as possible, to avoid questions from us.
Nov 20, 2014 | Computers & Internet
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Apr 08, 2014 | 1996 BMW 540i
Two lights blink and p2 flashes. it cant even initialise
Error No. P2 is a problem of Scanner board... kindly change your scanner board... it may help your problem... thanks.
Aug 20, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printer is freezing during initialisation and also giving error 49. It is also not copying.
This sounds like a Formatter Problem. This series of printers have a known problem with this component. The Formatter Hangs or Freezes the printer. The Formatter and scanner do need to be changed by an Authorized HP Warranty Repair Facility. It is possible that it may be covered under an HP Extended Warranty program. See repair information VIA posted Link.
M2727INFORMATION
Cheers!!
Dec 30, 2010 | HP Laserjet M2727nf Multifunction Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
Error code- 50 service
Hi Sheila,
The following page gives the reason http://www.all-laser.com/cgi-bin/webc.cgi/error50.html
Seems the printer needs something called a fuser. There is a link to maintenance packs including the fuser or just the fuser alone.
Apr 27, 2009 | HP Office Equipment & Supplies
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Error 50.6 in hp laserjet 9500hdn
  • HP II/III series most likely cause is the ac power module is defective. Order the HP II/III Service 50 Error Repair Kit. If the quartz fuser lamp is burned out, order the replacement fuser on specials page. Slight possibility of loose connector on DC controller. See tweaking page DC controller could also be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order the HP 4 Service 50 Error Repair Kit. Could also be a failure of the power supply.
  • HP 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating element.
  • All other printers most likely cause is burned out quartz lamp. In rare instances the ac power supply has failed. Even rarer, the DC controller is defective
Jan 22, 2009 | Office Equipment & Supplies
22 people viewed this question
Seeker5211
Seeker5211
