Question about Whirlpool GHW9150 Front Load Washer
Door lock Hi the washer is flashing F then DL which I assume means the door lock. How can I fix this? - Thanks
  • Susan Lindsey Feb 07, 2012
    The unit is a whirlpool - model GHW9150PW
    Top Expert:
  • Whirlpool Master
  • 75,822 Answers
These fault codes are caused by a failure of the main control circuit board (the brain of the washer), this is the board that is behind the washer control buttons.
Posted on Feb 07, 2012
  • 155 Answers
SOURCE: my washer is not starting in the selected mode. It
DL error stands for Door Lock.Follow the instructions to repair yourself.
Step 1
If your door hasn't yet locked and will not lock simply press cancel and try again.
If this will not work and the cycle still will not start up then skip to step three.
Step 2
If your door is already locked and you get an "F" error press and hold the cancel button and select drain/spin.If this still doesn't work and your clothes are trapped inside do not resort to getting out the crow bar and a sledge hammer.You can manually unlock the door by following these steps:
- Unplug washer or disconnect power.
- Remove the lower kick panel.
- Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
- Located on the bottom of the door switch/lock unit is a teardrop shaped tab.
- Gently pull the tab down about a 1/4˝ or until a click is heard.
- The door may be now opened.
Step 3
If your door fails to lock and your cycle will not start moderately but forcefully hit the back right hand corner of the washer with your fist.You may have to do this a couple of times,but you should hear the locking mechanism click so your washer is now locked.
Posted on Apr 06, 2010
  • 351 Answers
SOURCE: the washer goes for about 2 min. and the reg f 11
Fdl is a door latch error code. F11 is a serial communications error that is associated with either the door latch, central control unit (main computer) or associated wiring. Since you can hear a "click", and the washer works intermittently I would suspect you have a bad door latch assembly. Just to be sure you will need to check all your wiring connections going to the central control unit and door latch. To access follow these steps:
1. Unplug the washer.
2. Remove the three 7mm screws holding the top panel on. They are located along the top edge in the back of the washer. Once the screws are removed the top panel will slide back then lift up.
3. The Central Control Unit (CCU) is located in the central rear of the washer. You can't miss it. Make sure all the connections are plugged in snugly. The door latch connections are located behind the front panel on the right hand side. Check ONE connection at a time.
After checking wiring harness, run systems diagnostics test by performing the following:
Select DRAIN/SPIN, NO/SPIN, followed by pushing any button under OPTIONS 4 times. If entered correctly the display will read "C00" and you should hear the door latch "click". The diagnostics will run through a series of tests to include FILL, AGITATE, DRAIN and SPIN functions. Since the door latch is the first step of the diagnostic sequence, the tests will not progress if the door latch fails. You can push PAUSE/CANCEL any time to end diagnostics. Run this test several times. If anything fails you will get an "F" code in the display window. If the tests all pass, the unit will shut off, followed by an audible "beep" and the CLEAN light indicator will be lit. If you get successful results, then you know you probably had a loose wire somewhere. If the test fails, I would attempt to replace the door latch before the CCU. The latch costs considerably less. The CCU can cost as much as $220 depending on where you get it.
If you decide to replace the door latch follow these steps:
1. Make sure washer is unplugged.
2. Locate the wire hoop retaining ring that holds the rubber door boot on. It will be located behind the front edge of the rubber where it meets the door frame.
3. Locate the tension spring at the 6 o'clock position and stretch the spring apart to release the hoop. Pull the hoop from the bottom first and remove from the door boot.
4. Pull door boot from door opening and fold back inside wash tub so you can access behind the front panel of the washer.
5. Remove the three torx screws that hold the door latch on.
6. The door latch is seated in a plastic retainer bracket. Reach in behind front panel and carefully remove the door latch from this bracket so you can access the wire connectors.
7. Remove wire connectors.
8. Re-install wire connectors and latch in reverse order of how it was removed.
9. Re-install door boot, ensuring it seated properly all the way around the door frame opening.
10. Re-insert wire retaining hoop in the groove behind the front lip of the rubber door boot starting at the 12 o'clock position and working your way around to the 4 and 8 o'clock positions. (You may need a second set of hands for this part). While holding downward tension on the hoop to keep it seated, stretch the spring apart enough to snap the remaining part of the hoop back into place at the bottom of the door opening.
Run system diagnostics again to see if the latch functions properly and all tests pass. Good luck to you and I hope this helps you.
Posted on May 06, 2009
TERAMUS
  • 14 Answers
SOURCE: getting message F DL. ASSUME MEANS DOOR NOT
IT APPEARS YOU HAVE A MAGNETIC CONTACT FOR THE DOOR,YOULL HAVE TO HAVE A REPAIR MAN REPLACE THAT CONTACT,
Posted on Aug 30, 2009
SOURCE: washer reads dL f and door stays locked even
try to start another cycle then hit cancel and cancel again and it usually unlocks the washer
Posted on Apr 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet front load washer F dl door lock
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^&*
Posted on Sep 28, 2010
My washer flashes dl then flashes to F.
'dl' stands for 'door lock (error)' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Washing Machines
Hi I have an HE 3t model 110 SN- CSR3704321. I am getting an error code F dl. Im pretty sure it means "door lock" because the door isnt locking....is there anything I can do? Thanks
'dl' does stand for 'door lock' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
John C
Sep 17, 2011 | Kenmore Elite 45986 Front Load Washer
Hi, We have a kenmore Elite HE 3t front load washer. When we try to start the washer we are getting an error on the screen. The error flashes DL and then F. what does that mean? Thanks! Sabrina
'DL+F' stands for Door Lock Fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
John C
Apr 29, 2011 | Kenmore Washing Machines
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
It keeps flashing dl-f
Hi here is the meaning of the code and the corrective action needed. If you have any other questions please feel free to comment. Mike
"F/dL" Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Jan 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting message F DL. ASSUME MEANS DOOR NOT
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
My front loading washer wont start it flash E and DL i dont no what it means can you pls help me?
DL means door lock error. This happens when the door trys to lock 6 times but cant lock.
There a 2 things that create this problem. the door lock mechanism or the CCU ( central control unit )
Replace the door lock mech. first. if this does not fix the problem replace the ccu.
Nov 15, 2008 | Kenmore 46462 Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
