Question about GE DBSR453EBWW Electric Dryer
What year GE DBXR463 electic dryer manufactured
3 Suggested Answers
  • 21 Answers
SOURCE: GE Spacemaker Electic Dryer Poor Drying
Hello
Make sure you have a 30amp two pole breaker. Also, it could be a heater problem.
John
Posted on Jan 07, 2010
vostendorp
  • 347 Answers
SOURCE: my GE dryer DBXR463 electric dryer doesn't dry the
Check the entire vent (exhaust ) system start the dryer and go outside to the exhaust vent ,you should feel a good amount of warm airflow.bet you will fine low airflow. You need good air circulation to help remove the moisture from the clothing warm or hot temps alone would take longer if ever to dry ..this generally happens slowly over time and the next thing you realize is that its running much longer than it use to... plus it cost more....if you still have a concern you may have a thermostat that is short cycling not letting it get hot enough long enough... Hope this helps GOOD LUCK
Posted on Aug 22, 2010
WIRING SCHAMETIC FOR GE ELECT DRYER
hi greg.
go to this link and scroll down the page might help you out.
WIRING SCHEMATIC FOR GE ELEC DRYER Google Search
Nov 06, 2017 | GE Dryers
Tip
Determining the Age of Your GE Appliance
This advice applies to all appliances manufactured by GE. Determining the manufactured date of most appliances is accomplished by looking at the SERIAL NUMBER. On GE appliances this is determined by the following method:
The manufactured date is determined by the 1st two letters of the serial number
Example: FY456789
1st Letter is the MONTH
A – JAN
D – FEB
F – MAR
G – APR
H – MAY
L – JUN
M – JUL
R – AUG
S – SEP
T – OCT
V – NOV
Z - DEC
2nd Letter is the YEAR
A – 1977, 1989, 2001, 2013
D – 1978, 1990, 2002, 2014
F – 1979, 1991, 2003, 2015
G – 1980, 1992, 2004, 2016
H – 1981, 1993, 2005, 2017
L – 1982, 1994, 2006, 2018
M – 1983, 1995, 2007, 2019
R – 1984, 1996, 2008, 2020
S – 1985, 1997, 2009, 2021
T – 1986, 1998, 2010, 2022
V – 1987, 1999, 2011, 2023
Z – 1988, 2000, 2012, 2024
NOTE: Some Kenmore appliances are manufactured by GE and will have the following prefixes in the MODEL number:
362, 363, 464
on Sep 03, 2009 | GE Profile DPSB619ED Electric Dryer
How old is the GE ddg2788malwh dryer
There should be a manufacturer's sticker on the inside trim of the door frame, or on the back. On that, you should have a year of manufacture.
Dec 12, 2015 | GE Dryers
GE dbxr463 dryer-can i turn the finish signal off or change it to chimes or tones
John,
Usually you cannot change tones. Sometimes you can turn it down, but that usually would have the volume control right there on the panel. The only other thing that I can suggest is unplugging your dryer and open up the panel and find your buzzer and unplug the wires going to the buzzer. Wrap electrical tape around each of them separately so that you do not cause any shorts when you put everything back together and plug it back in. Hope this helps!
May 12, 2015 | GE Dryers
I have a GE electric DBXR463 Model dryer and am trying to get a copy of the schematic to open it up... It makes a very loud noise... and has a burnt smell aswell... It does start...along with all other...
common problem is the rear bearing....http://www.youtube.com/watch?v=U7f8pF64008....copy and paste and watch the video,if this doesn't look like your machine,open the door and if there's two screws on the top remve them and pull off the top panel and everything else will be the same.
Apr 09, 2011 | General Electric DBXR463EG Dryer
My GE dryer DBXR463 electric dryer doesn't dry the clothes all the way anymore? What could be the problem? I have cleaned all of the lint and checked the venting on the back. It used to worked fine for...
Aug 21, 2010 | GE DBXR463EBWW Electric Dryer
What year was the whirlpool LER5636P electic dryer made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. The following link explains to determine the date on a Whirlpool appliance:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The first two numbers in the serial number determine the WEEK it was manufactured (52 weeks in a year). The 2nd digit represents the YEAR. If you have any difficulties determing this, post back with your serial number and I can explain it to you.
I hope this helps you.
Feb 17, 2010 | Whirlpool LER5636P Electric Dryer
Hello
John
Nov 24, 2009 | GE Profile DPXH46EAWW Gas Dryer
My Brand new GE model DBXR463 does not start. I plugged it into 110 volts AC. The manual says single phase 120/240 V and I have 25amp circuit. When start is pressed nothing is happening. Somehow, I think...
If this is brand new i assume you will have warranty..First of all try the plug fuse, next make sure the voltage setting is correct for your area, I note what you say on this!..to check a timer properly you would need a diagram and multimeter,I wish you well good luck
Oct 02, 2009 | GE DBXR463EBWW Electric Dryer
I have a 2 year old GE DBXR463 electric dryer. It was working fine until I moved it to another home and changed from a four wire to a three wire connection. There appears to be some heat in the drum...
Must be a brittle coil broke and when the unit got powered up it has welded itself to the frame. Get the drum out and inspect this. GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 27, 2009 | GE DLSR483EE Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
64 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
