Question about Sharp ELW535 Calculator
I have a sharp write view EL-W535x calculator. i need to know how to enter the letter in an equation. for example X=1+2
informatica
  • 1114 Answers
SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Posted on Aug 10, 2007
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
  • 1126 Answers
SOURCE: need a manual for the sharp EL-5103S calculator
http://www.sharpusa.com/products/support/view_all_models/0,2326,32,00.html
I don't see that model listed...are you positive on exact model number?
Posted on Sep 05, 2009
  • 8068 Answers
SOURCE: Half-life exponential problem. Can't get the same answer as example
Here is how you enter it.
[+/-]0.693/8x4[2ndF][e^x][=] result is 0.7071588193 or as you wrote 0.7071
some calculators show an error message if you enter the [+/-] (the negative of a number before the number itself).
In that case enter 0.693 then press [+/-]. the calculator should put a small - sign before the 0.
You can try
0.693[+/-][x]4[/]8[2ndF][e^x][=]
Hope it clarifies things.
Posted on Sep 06, 2009
  • 8068 Answers
SOURCE: I have a SHARP EL-501W calculator and i am getting
The source of errors is most certainly due to the wrong schoice of angle unit (degree or radian). If the default angle unit set in your calculator is the degree, any value fed to the trigonometric functions (sin, cos, tan) is considered to be expressed in degrees. Consequently, if you calculate the arctangent ( tan^-1) of a value, the angle returend by that inverse trigonometric function is expressed implicitly in degrees.
Similarly if radian is the default angle unit in your calculator, any angle returned by an inverse trigonometric function (arcos, arcsin, arctan) is in radian.
Set the default angle unit as the one required by your problem at hand. This way, the angles returned will be in the right unit and you will not have a problem of interpretation.
Hope it helps.
Posted on Dec 07, 2009
How do I do algebra on a Sharp EL-W535x?
You can do it by hand.
8x-3x=64+8=72
Thus, 5x=72
x=72/5
Jun 30, 2014 | Sharp Office Equipment & Supplies
Linear equations sharp el-531
You cannot solve linear equations on a SHARP EL531. If you would like a calculator that solves equations, you need to get a SHARP EL W506
Apr 08, 2014 | Sharp el-531x scientific calculator
Is it possible to do exponents other than 10 on a SHARP El-W535X Scientific Calculator?
Use the y^x key (two keys up from the 7 key). For example, to calculate 8^9, press 8 y^x 9 =
Feb 04, 2014 | Sharp Office Equipment & Supplies
EL 531X Sharp - Help with calculations
You need a SHARP with Write-View display capabilities. The EL-531X is unable to show that. The Write-View calculators from Shard have a W, example EL-W516 followed by Write-View. Not to be confused with the W in EL-520W
Feb 21, 2013 | Sharp el-531x scientific calculator
How do I input an = sign into an algebraic equation using an elw535
There is no need to enter an = sign in an algebraic equation because the EL-W535 does not handle them. It has only 3 modes : The computational mode, a statistics mode and drill mode (to learn or practice operation tables). Thus any press of the = sign will execute the command you typed. If you just entered an expression, the = sign will have it evaluated using the current values of the variables you used. If you have not stored anything in a variable, the calculator will use 0.
You can use the 4 D keys to store a function key for example SINH^-1. You cannot even store in them an elaborate formula, just a function key or a shifted function key.
Sorry for the limitations of the calculator. To have more functions you should look for the EL-W516.
Mar 03, 2012 | Sharp ELW535 Calculator
How do i recieve answers on the El-W535x SHARP calculator in decimals, need it for buisness class...so if you could answer that question and tell me of any other functions i might be unaware of that might...
My name is adieh.have a great day.
I will give a simple example on how to convert your answer into decimal form. Indicated below:
Q: Simplify 1/2-5/13 convert to decimal
Answer:
Step 1: Enter 1/2 by pressing 1>a/b>2.
Step 2: Subtract by pressing - (negative sign or minus sign)
Step 3: Enter 5/13 by pressing 5>a/b>13.
Step 4: Find the difference by pressing = (equals sign)
Step5: Convert to decimal by pressing (change)
You can find( change) on the right side of your calculator beside M+ key
I am suggesting you to visit this website http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/Archive/cal_man_ELW535B_TeachersGuide.pdf
for you to have further knowledge about various functions of your sharp calculator since you are attending a business/algebra class.
Hope it helps.
Thank you for using fixya.
Sep 22, 2011 | Office Equipment & Supplies
I am trying to solve a quadratic function using the calculator but i dont seem to be able to do so. For example if i had a question like 5x^2 + 15x +3, how would i use the sharp el-w535 to find the x...
This expression 5x^2+15x+3 is not an equation, therefore it can have any value depending on the value of x. You have to make it an equation before looking for the particular value of x that satisfy your equation 5x^2+15x+3 =0
This calculator cannot solve equations because it does not have an equation solver.
Dec 15, 2010 | Sharp ELW535 Calculator
You can try
Sep 16, 2008 | Sharp EL-531VB Calculator
NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Jun 05, 2008 | Sharp EL-2192Rll Calculator
Sharp ELW535 Calculator Logo
742 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
