Question about Hotpoint Washing Machines
Hotpoint aqaurius wma31 washing still wet after spin cycle is the problem with belt tension
    Scholar:
  • 78 Answers
Dear Scotty12345,
It would not hurt to check the belt tension, but also consider looking at the thermostat, speen speed of the motor, and if there is a reset button on the machine. If there is a reset button, try pressing that, it may fix the issue if the machine spins with the element on.
If the above instructions do not help, get hold of me again and I will investigate the matter further for you.
Yours sincerely
Ouszen
Posted on Feb 07, 2012
Hotpoint 1050 model 9605 not spinning
direct drive has clutch and tranny. belt is belt driven. there is a tensioner belt switch that may have clicked off somehow? located at bottom of tensioner on motor. may also want to check the lid door switch, ( looks can be decieving as u say it looks to be working) check all with a multimeter for continiuty
Aug 08, 2014 | Hotpoint Washing Machines
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
My Hotpoint WMA31 will not drain - the smell is
check for blockage under cap bottom of washing machine
May 26, 2010 | Hotpoint WMA31 Front Load Washer
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
Wash is still wet after spin cycle
Hi!
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician
For further assistance need your machines model no.
Thanks
Rylee
Jan 30, 2009 | Hotpoint Washing Machines
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 spin WMA31
I have just had the same problem too, i fixed it by reattaching the belt and making sure that the belt at the motor was flush with the edge of the motor spindle, right at the end, it looks dodgy, but it works
May 29, 2008 | Hotpoint Washing Machines
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
try replacing the interlock first then check the the continuity in the interlock lead
Mar 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Clothes wet after spin cycle
if its not the belt its your brushes in the motor that need replaced
Jan 04, 2008 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
