Question about Universal Remote Control Osiris Complete Control Universal Remote
I have a Osiris MX-350 Universal Remote and I need to program it with 5 different devices. Looked at Manual and tried to make it work but no help
SOURCE: can't program mx-700 remote
Hello there,
I just had the same issue and solved it- its pretty easy as it turns out. check out
http://www.universalremote.com/resources/pdfs/MX600manual.pdf
This is the previous model owners manual but it works. You'll want to program using the "learn" mode where you point the remotes at each other.
Posted on Jun 22, 2008
  • 12 Answers
SOURCE: mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Posted on Aug 31, 2008
  • 26 Answers
SOURCE: Need manual to program remote to a different frequency
Each fan with have a receiver unit mounted in the housing, usually above the fan up against the ceiling. Each receiver unit will have 4 "dip pins" which allow the code to the remote to be set. In order for two fans originally installed with the same code to be run separately, one fan will have to be taken down, and the code changed on the receiver unit. Then you will have to purchase a new remote and set the same code on its dip pins (usually under the battery.) It's easiest to buy a replacement remote WITH a receiver AND a transmitter in it. You can either wire in the new receiver (setting the code differently than the existing one on BOTH the receiver AND the transmitter) OR just put the receiver aside and program the new code that you've set in the old one into the transmitter.
Posted on May 26, 2009
  • 63 Answers
SOURCE: need manual
'User Manual, user guide and the 'red button' at retrevo's site gets you the .pdf download:
http://www.retrevo.com/support/RCA-RCR311W-Universal-Remotes-manual/id/402ci571/t/2/
WW specialsystems@bizland.com
Posted on Oct 04, 2009
SOURCE: need remote code for Phillips
remote code for tv
Posted on Sep 16, 2011
Compatible with directv hr23-700
please try to add details like what you want to know. then only anyone will be able to provide you better answer... Electronics Equipment Repair Center
Oct 04, 2014 | Universal Remote Control MX-350 Complete...
I have a MX-350 universal remote and when I replace the batteries, it won't come out of "TEST" mode.
Could be a bad ground. Run a different ground wire and then try or sometimes the bulb housing is the ground, and the housing is not screwed in proper or it lost its ground somehow .
Mar 09, 2014 | Universal Remote Control MX-350 LCD Remote...
Can the Osiris mx-350 universal remote be programmed to control the Genie box from direct tv. If so, what is the code!
056,052,057,098,099 are the codes to check. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 19, 2013 | Televison & Video
How do I program my mx-350 to run at&t uverse remote?
Type this address into your "address bar" (long white bar on top of the internet explorer page)
www.universalremote.com/resources/pdfs/MX-350OwnerManual.pdf
Jun 28, 2011 | Universal Remote Control Osiris Complete...
Need instructions to set code for tv
  • 1 Download or view the user's manual from the Magnavox website (see Resources). You will need the list of codes included in the manual. The website will direct you to the closest remote control manual available similar to the REM 350 Universal Remote. This manual is compatible with the REM 350 Universal Remote.
  • 2
    Press and hold the "Code Search" button until the red indicator light stays on. Release the "Code Search" button.
  • 3
    Press and release the "Mode" button for the product you wish to program (TV, VCR, DVD or satellite). The red indicator light will blink, then stay lit.
  • 4
    Enter the four-digit code from the code tables listed in the user's manual. You can also search for the code online at the Philips Universal Code Finder page (see Resources). You might have to try several or all codes listed in the manual until you find the correct one. After a valid code entry, the red indicator will turn off. With an invalid code, the red indicator flashes.
  • 5
    Press the "Channel Up" button with your device on (TV, DVD, VCR, or satellite). If the device responds, you have completed the programming. Once are certain you have found the valid code, make a note of it somewhere so you will not have to search for the code again.
  • Jan 14, 2011 | Philips Magnavox REM-350 Remote Control
    Cannot get channel guide to show
    Besides the many features Osiris MX-350 provides as a universal remote control, it is also a learning remote.
    If pushing the button doesn't have the expected result, e.g. pushing the GUIDE button on the remote doesn't bring up the channel guide, you can teach the Osiris with the original remote.
    Instructions on teaching your remote a new command is included in the instruction manual.
    Since I couldn't find a code for my Sony blu-ray player, I just taught the Osiris all the commands from my original remote in about 10 minutes.
    Aug 16, 2009 | Universal Remote Control Osiris Complete...
    Most remote makers provide information and codes for programming their devices on their websites. check there for the instructions.
    Jul 05, 2009 | Universal Remote Control Osiris Complete...
    Lost battery cover
    You can call the company and give them the model number MX-350 and they sell for around $4.00 a piece. I bought 2 in case I lost another one.
    Call Osiris Universal remote @ 914-835-4484 or e-mail to repairs@universalremote.com
    Hope this helps,
    Webb
    Dec 12, 2008 | Universal Remote Control Osiris Complete...
    Universal Remote Control Osiris Complete Control Universal Remote Logo
    Top Universal Remote Control Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
