Question about RCA D52W23 52" HDTV CRT TV
TV Cycling through inputs
When I turn the TV on, it will cycle through all the inputs and not stop. I took the batteries out of the remote and unplugged the TV overnight and nothing helped. When I go to the Menu screen, it will cycle down to the bottom choice, as if I am holding the down button. Any help would be appreciated. Thanks.
  • dazed3547 Nov 18, 2008
    Thanks! TV works fine now.
  • RCA Master
  • 8,617 Answers
You need the signal board for an ITC222 RCA. The following link has them available under their RCA parts category.
http://servicemanuals.vstore.ca/
Posted on Nov 15, 2008
No remote and need to change input on a toshiba 27a45
If you do not have an input button on the TV then you need to get a remote. I have owned a lot of toshibas. Use the channel down button on the tv and keep hitting it untill you get down to the last channel. after that it should start cycling thru you inputs. Good luck to you.
Mar 21, 2013 | Toshiba 27A45 27" TV
How can i change the inputs on the tv?
If you have the remote, there should be an input or source button it? Also, check the buttons on the TV for an input/source button. If there isn't one on the TV buttons, try cycling through the channels, some TV's have the inputs change with the channel buttons too, once cycled down through the channels, it will go through the inputs before starting over.
Regards,
Brandon
Dec 09, 2010 | RCA L32HD31 32 in. LCD HDTV
TV Help!!
Yes , this sounds like the EPROM IC is failing or the crystal that keeps the frequency on the IC needs to be replaced , or even the buttons on the tv could be warped by the heat of the tv( if it is the buttons , then removing the control board from the plastic buttons will stop the random cycle and may make it so you can turn on the tv , but if not then it is the EPROM IC or crystal)
to check and see if the chip is messing up , hold down the menu button on the tv or vol up down and see if it stops cycling thru the video inputs
electech
Nov 21, 2008 | Televison & Video
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
TV will not come on and if it does it just cycles through the channels...
If tuner channels keep cycling,why not by-pass the problem?
Use audio / video inputs as source from box or VCR tuner....
Saves money every time !.............................T.
Dec 01, 2007 | RCA F32649 32" TV
Menu rotates
Had the same problem with the Mitsubishi ws 48511 model. A solution posted in FixYa worked great and might be worth trying as they have very similar electronics and panels -- did you check to make sure that one of the front panel buttons isn't stuck in the depressed postition? For me, the device menu kept cycling and remote wouldn't work. Sure enough, the button was stuck pushed in. It was hard to even notice, but took little effort to get it free. Good luck.
Nov 13, 2007 | Mitsubishi WS-55711 55" Rear Projection...
What do I do for tv switching from tv to various video modes and cycling through set up screens
the tactile switches on the control panel cause this problem . they could'be stuck or have some kind of contamination like liquid. or just bad . cost to repair aroud 60.00 dls if this helps please let me know
Jun 12, 2007 | Toshiba 35A44 35" TV
RCA D52W23 52" HDTV CRT TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
