SOURCE: Acer One 1542 series not boot
Take out the battery and the mains power, turn the laptop over
and remove the ram cover, look for the ram and take it out by pushing
the metal lugs outwards so the memory pops up, it's now ready to
remove, the ram (memory) looks like this >>>>>>
Once
the memory is out look very close in the memory bay for 2 brass
triangles, they will be in the shape of a diamond, get a flat head
screwdriver and short them 2 pins out, this will clear the CMOS, put
the memory back in, turn the laptop over and plug in power & hit
the on/off button.
When it comes it will say that bios settings are
wrong so go into the bios and set the time and date, save the changes
and exit the bios, the computer will restart and hopefully boot up with
no more problems.
Hope this helps.
Good luck.
SOURCE: Hi there I have a HP
i got the solution to this problem, watch the vid i made for all of everyone to use for the solution.
SOURCE: model: hp dv5-1002au os: windows
So there is your screen resolution issue.
For that when you power up the laptop press continue F8 key then enter in "Enable vga mode " then go to control panel and display proeprty then go to settings then change screen resolution to 1024*768 then apply then restart then check .
If you cannot able to see safe mode and other menu whne you press F8 then your Dispaly has hardware issue because your motherbord working fine it gives dispaly proeprly to vga.
If you have vga port on laptop and you have other external monitor you can check it.
Connect your monitor to vga port then if it gives diaplay then some rong with your Laptop internel dispaly screen and if it is in warrenty you can use warrenty they repalced or repair your screen.
SOURCE: No display. When the system boots no dispaly is
If all three are flashing likely a failed motherboard, try these steps, if they fail, then replace the MB:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
The laptop do the logo but before go further , the 3 leds blink fast, then after like 30s goes of.
I have take off all the peripherals , but the result is the same.
