Question about Home
Leak from back of countertop sink
Have notice a leak from the back of a countertop Ronbow 200032 sink in our master bath. The sink is mounted on top of the bathroom countertop, and the faucet is mounted about one inch behind the sink. The leak is definitely coming from exactly where the back of the sink meets the countertop, not the faucet, and the sealant/caulk there is definitely come loose. If one looked staight down at the sink from above, O is the facucet and x is where the water comes from and D is the drain. O ________x_________ | | | D | |-------------------------------| If one looked at the sink from a back profile, the water comes from under the bottom of the sink, right under the the L in the following diagram: __________________ | | |________L________ | I see no evidence of water anywhere in the cabinetry under the countertop. I was tempted to just reseal around the leak, but then I might just be sealing in the problem. There must be a leak somewhere that is allowing water to get under the sink itself. Any thoughts?
  • quatroch
    quatroch Feb 07, 2012
    Ugh, sorry, my diagrams did not come out at all.
  • yadayada
    yadayada Feb 07, 2012
    I suggest you seek the help of a contractor.
kachbibi1
  • 979 Answers
SOURCE: bathroom sink
You won't for long. There is some stuff on the market that can immulate porcelain, but it won't hold for long. It really won't look the same. Now, if you are looking for practicality, and it doesn't leak, then keep it, otherwise, get a new one and you will be pleased with what is on the market now and the selections.
Posted on Feb 03, 2009
  • 2976 Answers
SOURCE: Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Posted on Feb 21, 2009
  • 659 Answers
SOURCE: Leaking kohler faucet
Where the spout pivots on the main body, there are a couple of washers, you can replace these washers pretty easily by removing the handle and then the "cover" from the unit. The water has to be shut off before you do this. I would take this oppurtunity to replace all the washers.
Posted on Mar 19, 2009
  • 74 Answers
SOURCE: Grohe 32 071 K4 spewing water from single vale or tube under sink
There should be an o-ring on the mating surfaces of the hose and the faucet that my be missing.  It could also me that the big washer in side of the faucet (under the cartridge) has been shifted.
I doubt it is the cartridge itself, always try the cheap ideas first.
Posted on Apr 14, 2009
gary1121
  • 332 Answers
SOURCE: Vessel sink drain causes poolin of water.
YOU ALSO HAVE A VENT ISSUE, THE VESSEL SINK DOESN'T HAVE THE LITTLE HOLE IN IT LIKE A VANITY SINK, THERE FOR THE WATER IS GOING DOWN THE DRAIN BUT THE AIR CAN NOT COME OUT, YOU NEED TO INSTALL A STUDOR VENT OR AN INLINE VENT INTO THE DRAIN BETWEEN THE WALL AND THE TRAP CUT IN A TEE AND BRING A PIPE UP TO THE BOTTOM OF THE COUNTER TOP AND INSTALL THE VENT, USALLY HAVE TO PUT A FEMALE ADPT ON THE TOP OF THE PIPE THE VENT COMES WITH THREADS DO NOT GLUE IT IN PLACE, THEY HAVE A RUBBER FLAPPER THAT OPENS WHEN THE WATER IS GOING THRU THE DRAIN AND ALLOWS IT TO PULL IN AIR THEN THE FLAP CLOSES WHEN NO WATER IS RUNNING TO KEEP THE SEWER SMELL OUT
Posted on May 29, 2009
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
Freuer faucet leaking
Contact Freuer faucet and get free replacement parts. I was even sent complete unit that I had to install.
Mar 21, 2014 | FREUER Faucets Countertop Sink Mount...
How would the swanstone kssb-3322-015 black galaxy look with black galaxy countertop? Thanks!
They will always look great with any back ground of counter top due to their unique look and under slab mounting.........Great choice........Hope this helps.
Apr 19, 2011 | Swanstone KSLS-3322 Double Bowl Kitchen...
We bought a Franke top mount sink and go system from Lowes. It is being installed in a standard formica countertop. The clips that came with the unit will not stay on for anything when you attempt to...
Is the Foot print of the replacement maybe sink smaller than the foot print of the orginal sink that was replaced? It sounds like it is. Make the hole smaller by cutting a plywood strip to be placed on two sides of the sink hole. Long side at back of sink and short side. (plywood needs to be marine type because of the high mosture of the sink area and painted)
I went to their web site; they have posted a buyer beware notice of bad contractors. They may be able to help.
info@frankekitchensinks.com
Nov 27, 2010 | Franke Home
Lavatory distance from front of countertop
There is no standard. Customarily the lavatory will be centered between the front and back of the cabinet as measured from the inside. Different styles of faucets (deck mount or sink mount), lavatories (self rimming or undermount), and customer provided preference can all affect the reveal from the lav to the front of the counter top as well as the length of the countertop reveal itsself
Apr 15, 2010 | Home
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Can not get level. countertop and sink top level.
the castng on most sinks is rarly perfect, if ever. i find they always rock to some degree, thats why you sillicone them to your level counter top, besides keeping splashed water from making it's way underneath.
Aug 16, 2009 | Home
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Home Logo
1,120 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
