Question about Maytag Washing Machines
What does f o5 code mean
After 5 minutes after start up machine stop and flashes fo5
    Top Expert:
  • Maytag Master
  • 76,164 Answers
F05 code is a water temperature sensor problem, It may be a broken wire at the plug for the heater, I'd recommend removing the back panel there is a plug (2 black wires) if i remember correctly ,one wire was just hanging there, board picks up on that causing sensor code, cut the plug in half and joined wire directly to heater terminal
Posted on Feb 07, 2012
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
E20 is "A problem with water draining" Solutions: The drain hose may be squashed or kinked The drain pump may be blocked
Posted on May 21, 2007
jackboy
  • 2985 Answers
SOURCE: Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Posted on Jul 31, 2007
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
Have you had a storm or power surge lately. May need a new electronics panel installed. That is what happened to mine. Once it is fixed, you should get a surge suppressor that is made for major appliances
Posted on Apr 27, 2008
jsrock516
  • 5911 Answers
SOURCE: F-5 error code on Kenmore elite HE3 45872
Click on the following link for a full explanation of the "F05" error code:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
This is not a difficult repair. The error indicates a failure of the heating circuit. If you are not sure of how to diagnose this yourself, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Posted on Jun 12, 2008
techbuster
  • 5081 Answers
SOURCE: I washed a large load in our Whirlpood Duet
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
You can download the online repair manual in the below link
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Posted on Jun 27, 2010
After few minutes lights start flashing and the machine stops. when opened the water has not drained away?
Guessing you have a Kenmore HE? The flashing light is actually a code it is giving you. Your manual has the meaning of the code flashing and will tell you how to repair it. Count the flashes, then get your book out and go to "troubleshooting".
Mar 26, 2015 | Washing Machines
The wash cycle stops after about 5 minutes and the timer starts flashing "H" and "F" repeatedly. what does this mean? i usually unplug the washer and its fine but its happening more frequently.
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Check the water inlet valves for any clogs and try to clean it, also clean the screens in the inlet valve. If still it’s not resolved then the only option is to replace the valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fo5 flashes on hotpoint ultima washing machine
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Please rate my solution,
Thankyou.
Feb 01, 2010 | Washing Machines
Machine wont empty and all lights flashing with a fo5 code
Fo5 indicates pressure switch jammed on full.
To rectify the problem, do the following.
Remove large black hose from bottom of drum
Remove and clean plastic filter inside hose.
Remove hose from pump, and check for blockage or obstruction here as well .
Please rate my solution.
Thankyou.
Jan 24, 2010 | Hotpoint Washing Machines
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Will not display picture or eject tape.
most of no signal means dsr 11 or similar machines have dirty heads. When they get dirt sometimes, you can´t play a cassette and the machine turns off (with the cassette in).
I´ve tried several times to reload the cassette and I manage to make it work again.
with the cassette in and the machine off press at the same time power and fast forward.
When in fast forward press play and your head should be starting to be clean (takes 4 o 5 minutes
to get a clean picture). Normally the machine gives a code error like if it was a loading problem but
not nearly related
Mar 13, 2009 | Panasonic Televison & Video
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
