Question about Mitsubishi WS-65511 65" Rear Projection Television
Hello. I have a Mitsubishi ws-65511 that does not have a picture or sound. A green flashing lite blinks too quickly to count the number of flashes and must be over 30-50 before it pauses. Do you think it is the capacitors that need to be replaced?
  • 1,383 Answers
I think if you pull the back cover off it will have a few sets of leds that will tell you whats wrong. be careful not to touch any of the high voltage circuit boards
Posted on Feb 07, 2012
  • 87 Answers
SOURCE: Mitsubishi WS 65511 convergence
Go on line and get an original Sanyo STK 393-110. Next, restore the blue centering rings back to where they were before you moved them. Look at the paint marks on the rings for reference if you are not sure. Replace the IC and check the resistors nearby for signs of overheating and proper value. Also check the fuses that supply the 24v to the IC. The service manual will show you the fuse location and give you the resistor values in the blue horizontal and vertical circuit. Checklist: You need a de-soldering tool or a good quality Dry Wick. Have a small tube of heat sink compound to liberally apply to the new chip. The hardest part will be lining up the double rowed pins on the chip and getting them to seat at the same time. Next, go to the convergence menu and follow the instructions. Good luck! PS you might want to remove the chassis from the cabinet to make it easier. Be careful to unplug the speaker plug and untwist the wire ties from the cabinet. Be very careful, this job is not designed for beginners.
Posted on Mar 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi WS-65511 HDTV
How many times does it blink? Or is it a continuos blinking that doesnt stop? Let me know and I will be able to help you with it.
Posted on Apr 30, 2008
Slinteriors
  • 8617 Answers
SOURCE: MITSUBISHI 65" RAER PROJECTION TV MODEL-WS 65511
Try to press both the menu button and the input/device button on the set both in together and hold in for 6 seconds to see if the led will blink a two digit blink code, then let me know the two didgit code, and I will try to assist you. Please respond to this same post when replying.
Posted on Aug 08, 2008
SOURCE: No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
Posted on May 12, 2009
ladywinn
  • 5138 Answers
SOURCE: mitsubishi ws-65511 Green light blinking found bad
Front Keypads go bad alot on these sets,replace the Keypad.
Posted on Dec 24, 2009
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
Wont restart after power outage. Model WS-65511
Do you get a flashing green led? Or is there nothing going on at all?
Apr 04, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Blinking green light
Contact a Mitsubishi service center and tell them the count of the pattern of flashes of the green light (Usually 2 - 9 flashes, a pause and then repeats) It will not be user serviceable.
Mar 30, 2010 | Mitsubishi WS-65869 65" Rear Projection...
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi 65" model # ws-65511
The steady green blinking led is due to the DM not completeing the boot Cycle. You can get the repair kit at the following link which contains the replacement Capacitors and step by step detailed instructions so you can do the repair yourself. Very inexspensive Kit
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Mar 02, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Help on Mitsubishi WS- 65513 65 in.
Look around online and find that this is a huge problem with Mitsubishi rear projection tv's. It is the board that needs replacing at $1100. My tv is 3 years old and already a big paperweight. Blinking green light of death.
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
